Old 05-02-2010, 06:48 AM
jmmcclosky jmmcclosky is offline
Skip FF#2 dosen't work on 45 Hauppage
I've tried to link this, but the infrared is sending the wrong command. When I go to "Show Sage TV Commands linked to Infrared /Keystroke" and press the >| button on the remote, what is displayed is:
Ctrl
None
I believe the command should be Ctrl+F5
I've tried to link to just the Ctrl command, but it doesn't work. Probably see it as an incomplete command.
Any idea on how to change this?
Old 05-02-2010, 08:51 AM
freedml freedml is offline
You can link any remote key to any SageTV command by using the other choice on that menu.
Old 05-08-2010, 02:07 PM
Why don't you go to the Detailed Setup-Commands-Link Infrared\Keystroke to SageTV Commands and scroll to the FF2 comand and press the button on the remote that you want to use for that command? Skp Fwd2 is Ctrl-F8. Skip is Ctrl-F. Linking remote buttons is all covered in the manual that was installed with SageTV.
skip forward #1 does not work in sagemc JohnLG SageMC Custom Interface 0 01-12-2010 03:43 AM
Sage dosen't know which STB to use. EdPhotoguy SageTV Software 8 12-18-2008 01:00 PM
Anybody know if a Hauppage 1250 will work david1234 Hardware Support 7 06-25-2008 10:33 AM
Can't get the Hauppage 350 to work. theshadowx SageTV Linux 0 01-13-2008 11:58 AM
Does Commercial Skip Work Through The MediaMVP? Schmoe SageTV Customizations 1 10-25-2005 09:36 AM
