Old 05-22-2010, 02:46 PM
nyle nyle is offline
I'd like to make my own skin - API guide?
I know the beta just started but I'd like to try my hands at a new skin for Sage 7. Is there documentation on the format for skinning? Thanks.
Old 05-22-2010, 08:38 PM
GKusnick's Avatar
GKusnick GKusnick is offline
Depends on what you mean by "skin". If you mean a theme (UI graphics and color scheme, with no changes to menu layout or function), see Theme.properties in SageTV\SageTV\STVs\SageTV7\Themes\Standard SDTV.
If you mean a full-function UI replacement like SageMC, or an STVI that alters menu layouts or functions in the stock UI, see the resources in the Studio forum.
-- Greg
Old 05-22-2010, 10:23 PM
Thanks, I misunderstood the intent of the skins system. I thought they were going to wrap menu layout into them as well. A standard system for creating and using them would be ideal Then everyone that doesn't like the UI layout can just select a new one.
You could them have skins that looked like other systems if some prefer their look but not power.
Thanks for the heads up.
-Nyle
Can I Make Time Row Font Smaller On The Program Guide Savage1701 SageTV Customizations 0 09-01-2009 04:33 PM
Any way to make it so if you press Guide button twice it closes open guide? vorius SageTV Software 9 09-08-2006 12:27 PM
How can I make MarkerHDTVDot & MarkerFirstRunDot to appear larger in LiveTV Guide? mkanet SageTV Customizations 6 11-04-2005 09:07 PM
V2.0 Skin help Potatophysics SageTV Beta Test Software 3 03-09-2004 10:33 PM
