Old 07-08-2010, 01:06 PM
PLUCKYHD PLUCKYHD is offline
Help with creating a playlist from Temp Media Files
I am having issue creating a Playlist from Temporary created MediaFiles. The do not have a sage id (and won't) but then at the end I am adding a MediaFile that does have a sage id. The end result is only the MediaFile is getting added to the playlist.
I am using sagex to build this playlist in java as follows
 Object NewPlaylist = sagex.api.PlaylistAPI.AddPlaylist(NewPlaylistName);
  File[] TempFiles = ListOfTempFiles
I then loop through and add the TempFiles to the playlist like so
Object TempMediaFile = sagex.api.MediaFileAPI.CreateTempMediaFile(TempFiles[i].toString());
 sagex.api.PlaylistAPI.AddToPlaylist(NewPlaylist,TempMediaFile);
I then add the MediaFile to the end of it and it seems to be the only thing getting added any ideas?
Old 07-08-2010, 01:19 PM
To add to this on log printout it is creating the TempMediaFiles but it is giving them all the same MediaFileID of "0" should that be the case?
Old 07-08-2010, 01:25 PM
I think when I played with this, i tried doing something very similar, and the result was that CreateTempMediaFile() could only ever create a single temp file, and a second call would simply overwrite the previous call. Because of that, I found CreateTempMediaFile to not have much value, especially when you could have multiple clients, etc.
I was using it to dynamically build up a playlist of .vob files so that I could watch DVDs on my placeshifter clients, but in the end, it didn't work.
I thought that somewhere there was a discussion about it, but I'm not sure where, maybe for CreateTempMediaFile and you might hit on that thread as well.
Old 07-08-2010, 01:30 PM
I read that thread and I am pretty sure Jeff said there would be a fix in the next build. That was probably 3 builds ago.
Old 07-08-2010, 02:00 PM
Narflex's Avatar
Narflex Narflex is offline
Sage
This should work...the only caveat was that you can only add temp media files to the now playing playlist (since that's the only temporary playlist and you can't save a temporary media file into a persistent playlist which will exist in the DB). If it's not working as designed, let us know.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 07-08-2010, 02:19 PM
GKusnick's Avatar
GKusnick GKusnick is offline
I have done this (adding temp MediaFiles to the Now Playing list) and it works fine for me. In my opinion this is the only sensible way to use temp MediaFiles anyway; adding temporary files to a permanent playlist is not a well-defined concept.
-- Greg
Old 07-08-2010, 02:24 PM
I agree I didn't even know the know playing list existed until now.
But I am still not able to get this to work as it won't add my temp media files to the playlist even though it shows it creates the temp media file.
I have changed the above to this
 Object NewPlaylist = sagex.api.PlaylistAPI.GetNowPlayingList(UIContext);
It still is only adding the file with the mediaid and not the temp files although the log tells me the temp files are created fine.
Any ideas Greg?
Old 07-08-2010, 04:52 PM
GKusnick's Avatar
When in doubt, strip it down to basics and see if that works. Then build back up from there.
For instance, try this in Expression Evaluator:
AddToPlaylist(GetNowPlayingList(), CreateTempMediaFile("C:\\somedir\\somefile.mp3"))
Does that work? Can you see the track in the Now Playing list in the Music browser? If so, try it again with a different filename. Do both tracks show now?
Now try writing a loop in widget code to add multiple files from an array. Test it using Execute Widget Chain. If that works, then try using sagex APIs instead of the built-in APIs.
In short: debug. There's an error in some code somewhere, so test each piece in isolation to figure out where.
-- Greg
Old 07-08-2010, 05:07 PM
You said check if it shows up in music this works for videos too right? Just double checking I think so but your comment through me off.
And yes going to start in studio and do process of elimination thanks for the advice
Old 07-08-2010, 06:01 PM
GKusnick's Avatar
Yes, it works for videos. Either playlist browser (music or video) can show you the contents of Now Playing.
-- Greg
Old 07-08-2010, 06:03 PM
Okay thanks for the clarification. I will start in studio using the default sage methods and go from there.
Old 07-09-2010, 06:27 AM
From testing I don't think the nowplaying playlist shows up in the playlist section. I can add items to a the playlist and verify they are there by playing it but it does not show up in the playlist section of the ui.
Old 07-09-2010, 10:32 AM
GKusnick's Avatar
Sure it does. It's not in the quick-pick playlist flyout on the Main Menu, but if you actually enter the Playlists section of the music or video browser (using Select instead of right arrow, grrr), it's there.
-- Greg
Old 07-09-2010, 11:27 AM
Yup you are correct darn right arrow and select gets me everytime
settings related to live tv temp files? vince100 SageTV Software 1 11-09-2009 06:51 AM
stopping HD-PVR from creating files tvmaster2 Hardware Support 8 09-07-2009 02:20 PM
stvxxxxxxxxxxxxxxx.img files in C:\temp mkanet SageTV Software 4 04-15-2009 11:28 AM
Moving thumbs and other temp files? MattHelm SageTV Software 3 02-19-2007 09:36 AM
Creating and Repeating a Video Playlist rolandtroisch SageTV Studio 2 02-06-2006 03:15 AM
