Old 10-24-2010, 09:31 PM
lobosrul's Avatar
lobosrul lobosrul is offline
MKV Subtitle Metadata Showing in Videos Instead of Title
I have many mkv's with subtitles, and most of them are labeled "English". Under the imported Videos section of SageTV they now all show up saying "English" instead of the filename of the video. I know this can be fixed by deleted the name tag under the subtitle using mkvmerge's header editor, but thats going to be a very time consuming PITA for me.
Actually Sage will show the subtitle name of an mkv only if all the audio names are blank, and all the video names are blank, and the tittle tag is also blank. The filename is used if they are all blank, which I think is what most of us want. It makes absolutely no sense at all to list the name of a subtitle or audio track as the name of a video!!!
Can this please be fixed in the next RC, its annoying me to no end. I think it would be a very easy bugfix. My apologies if theres a setting somewhere that fixes this, but I've searched extensively.
Old 10-25-2010, 11:34 AM
Narflex's Avatar
Narflex Narflex is offline
Sage
Go into detailed setup->advanced and do a library rescan there and then you should be ok. This was due to a bug earlier in the beta cycle which we have fixed since then.
If that doesn't fix it, submit a bug report.
Jeffrey Kardatzke
Google
Founder of SageTV
internal mkv subtitle support? loomdog32 SageTV Software 2 10-08-2009 12:11 PM
Subtitle options not showing up for MKV files subhadipsas SageTV Beta Test Software 1 04-30-2009 05:53 PM
video file metadata (title, description, etc)? davidjade SageTV HD Theater - Media Player 0 01-30-2009 08:12 PM
.mkv subtitle support on HD Media Extender MichaelFraser SageTV Media Extender 6 05-05-2008 09:51 AM
Toggle On Subtitle when playback a mkv file? TechBill SageTV Software 3 02-19-2008 03:24 PM
