Old 02-15-2011, 07:40 PM
bollockz bollockz is offline
HD300 Menu vs Sage7 client menu
I been using the sagetv7 client for a while and just sprung for a couple HD300 boxes. First thing i noticed is the the menu bar on the HD300 is on horizontal. How can I get this vertical on the left as it is on my sage7 client?
Old 02-15-2011, 08:08 PM
GKusnick's Avatar
GKusnick GKusnick is offline
If you're using it in extender mode, it should show the same UI as your server. If you have UI mods plugins installed on your SageTV Client that change the menu layout, you'll have to install those same plugins on the server to get them to show up on the extenders.
If you're talking about standalone mode, the HD300 standalone UI hasn't yet been updated for V7.
-- Greg
Old 02-15-2011, 08:16 PM
ahhaa apparently there was a mod enabled that was causing this. Weird how it didnt show up on the client but did on the extender
Old 02-15-2011, 08:24 PM
GKusnick's Avatar
UI mods installed on the server affect the server UI, extenders, and Placeshifter clients.
SageTV Client mods must be installed separately on the machine where the client software is installed.
-- Greg
Old 02-16-2011, 05:25 AM
PLUCKYHD PLUCKYHD is offline
Just FYI this a older plugin and doesn't work with some o the menu mods. But if you aren't having issues enjoy
It seems more people use that then I though guess diamond needs a horizontal menu...
Old 02-16-2011, 06:29 PM
spike5884's Avatar
spike5884 spike5884 is offline
I have been wondering for a while and confused on what the difference was. Now I know. Something like this needs to be put into the manual. The manual is rather slim on Plug-ins/Mods in general and how they affect the different 'clients'. I am not talking about detailed information on the mods themself, just general information on what is possible, what different install types mean, and so on.
Scott
aka Spike5884
Icons on sage7 main menu/start SomeWhatLost SageTV v7 Customizations 29 02-15-2011 07:49 PM
missing selection icon in DVD menu, and how to select root menu brantmacga SageTV Software 6 01-18-2011 09:53 PM
Hd300 - Malore Default Recordings Menu? skyeclad SageTV v7 Customizations 2 12-02-2010 05:42 PM
Pressing info and menu button in 6.3.9 no longer shows the applicable menu LehighBri SageMC Custom Interface 3 04-02-2009 12:05 PM
Where can I find the menu title theme (Main Menu, Program Guide, Setup Menu, etc) mkanet SageTV Studio 5 11-11-2005 04:55 AM
