Old 11-04-2004, 01:17 AM
ruel ruel is offline
2.1.10 - TV not resizing or slow resizing when go between menu PIP to fullscreen TV
Hello. I've upgraded to 2.1.10 and it seems to work okay with my ATI E-Home Wonder card and my Creative VBDVCR card. The only issue I have with 2.1.10 is that the TV picture does not instantaneously resize when going from the PIP-size TV picture when in a menu to when you go fullscreen with the TV picture. The fullscreen TV would be all black except where the PIP would be if the menu was still there. And then it takes a moment to fill the screen. And vice versa when going from fullscreen TV and to a menu that has a PIP like in the EPG, the PIP in the menu only has part of the right upper portion of the fullscreen TV picture as if you're zooming in on that part of the TV picture. Have to exit out of the menu (to go to another menu) and go back to get the TV picture to properly fit the PIP. Strange and disappointing. I'm assuming that this can be fixed. I tried rolling back to 2.0.19 which worked fine for me but SageTV crashed on me so I'm stuck with having to use 2.1.10 unless this can be fixed either with a new version or with a tweak that I don't know about.
[Edit: I did an uninstall of 2.1.10, re-installed 2.0.19, and did a System Restore to get 2.0.19 working once again for me. So I'm happy again. ]
ruel
Visit http://ruel.net and check out the PC-TV section
