Old 09-27-2011, 07:51 PM
sageuser8 sageuser8 is offline
multiple tuners all tuning to the same channel
I have just done a RE-install of SageTV 7 on a system using 3 internal tuners connected to cable boxes, each of which is controlled by a UIRT (acutally a UIRT and two additional outputs from a splitter plugged into the back of the UIRT). All the hardware and software are the same as before the reinstall of SageTV (when everything worked fine), but I am now having a problem with the tuners: whether it is a manual recording or a scheduled recording, the last tuner tuned causes the other tuner(s) to be tuned to THAT channel. In other words, the first tuner tunes properly. When I select a channel on the second tuner, it puts THAT channel on the second tuner, plus the first-tuned tuner. When I select a channel on the third tuner, it puts THAT channel on the third tuner, plus the two previously-tuned tuners. I am CERTAIN it is not being caused by the emitters “leaking” over to the other tuners. (I have each cable box/emitter in a separate box taped up with electrical tape. Also, when I navigate to the SETUP VIDEO SOURCES part of SETUP and navigate to the CHANNEL SETUP I am able to tune each individual tuner and confirm it's on the correct channel via the PREVIEW THIS CHANNEL option—when I tune the tuners THIS way, each tuner stays where I put it, even after tuning the other tuners to different channels.)
I'm pretty sure I have isolated the issue to being a software problem, but who knows. My system consists of the following:
Dell XPS 410
Windows XP MCE
SageTV version 7.0.235
My tuner drivers are up-to-date
I hope I am posting this in the correct place--if another place on the forum is better, please let me know. I am a forum newbie.
Does anyone have any ideas about how to fix this issue? I really appreciate the help.
Lee
Old 09-27-2011, 08:30 PM
Here's a recent post which talks about the changes you need to make to the .ir files to run multiple IR emitters from a single USB-UIRT:
http://forums.sagetv.com/forums/showthread.php?t=57092
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i7-7700T CPU, 32GB Memory, unRAID 6.9.2, SageTV & OpenDCT Dockers
Clients: Multiple HD300 Extenders, Multiple Fire TV Stick 4K w/MiniClient
Old 09-28-2011, 03:10 PM
Thanks so much! I was about to give up on this and now all is well. I appreciate very much you taking the time to help.
Take care, Lee
Sage Not Using Multiple Tuners On Back To Back Shows on Same Channel Savage1701 SageTV Software 0 01-15-2010 07:28 AM
Multiple Clients, 1 channel...how many tuners? Trepidati0n SageTV Software 3 07-07-2009 02:34 PM
Multiple ATSC Tuners... STV's channel selection criteria? transco SageTV EPG Service 3 06-30-2009 08:48 AM
Multiple tuners, multiple extenders watching live streams tommymc General Discussion 4 07-03-2008 02:58 PM
Different channel setup with multiple tuners? pjpjpjpj SageTV EPG Service 11 03-22-2008 04:11 PM
