Old 11-01-2015, 06:42 PM
craigap craigap is offline
Google Drive Folders as import directories
I was trying to set my photos folder in google drive as an import directory for sagetv to pull pics from, but it comes up with an invalid directory once I get into the actual Google Drive folder on my PC. Is this expected behavior? I don't know much about how Google drive works, but it seems to keep a local copy of everything on my PC that I would presume be accessible like any other folder from Sagetv import directories.
Old 11-02-2015, 10:53 AM
Naylia's Avatar
Naylia Naylia is offline
The default location for google drive is: C:\Users\<user>\Google Drive
You can find me at Missing Remote. Or playing FF XIV. For XLobby users: XLobby MC
Old 11-02-2015, 12:03 PM
I know that much. I've also tried moving it to other locations without success. Anyone here use Google Drive and successfully able to get Sage to see it as an import folder? Sage seems to see the directory up to "C:\Users\<user>\Google Drive" but nothing beyond that.
Old 11-02-2015, 02:49 PM
Tiki's Avatar
Tiki Tiki is offline
I haven't tried, so no idea if it an/should work, however...
Are you running Sage in stand-alone mode or service mode?
If service mode, have you configured it to log in with a real user account?
Does that user account have access to read/write that file location?
,USBUIRT (multi-zone)
Source:
Comcast/Xfinity X1 Cable
HDHR, HVR-2250, HD-PVR
Old 11-02-2015, 05:46 PM
I am running in service mode. Could you expand upon what you mean by the log in with a real user account. I don't think I know what that means.
Old 11-02-2015, 08:22 PM
From the SageTVServiceControl.exe program, there is an option to choose who the service is run as. By default, it is run as LocalSystem, which likely doesn't have access to the Google Drive folder. From there, you can change it to run as your actual user account, which likely will solve the problem.
Old 04-25-2016, 02:18 PM
I've been successful at getting sagetv to see my google drive folders by changing the user account from "Localsystem" to my user account name, but I'm wondering if this caused a new issue for me. My server was inadvertently restarted without knowing it, and I noticed that my HD300's could not locate the server. My server is set up with a password and I'm thinking that because I wasn't logged in due to the restart that the service maybe never started, thus the HD300s could not locate the server? Is this an accurate assumption? If so, is there a way to get the google drive folders setup, so that they can be read by sagetv with the service logged in with the default "Localsystem"?-assuming that having the service logged in as "Localsystem" would fix the issue of the server being restarted inadvertantly and not being logged into windows using my user account.
Thanks.
Old 04-27-2016, 05:07 AM
Thanks.
The service will start up just fine whether the user is logged in to the console or not, as long as the username and password are set properly.
Old 04-27-2016, 09:58 PM
tjchuck tjchuck is offline
craigap,
When I installed google drive I changed the default location to something that was easier to find. in my case I put the location on a D:\google drive. From there Sagetv finds all the pictures and video files easily.
hope this helps.
Cant import dvd directories jkhouw1 SageTV HD Theater - Media Player 31 12-21-2009 09:26 PM
Import directories viperdiablo SageTV Software 0 12-13-2008 06:13 PM
Trouble with network drive in import directories CatsLab SageTV Software 2 11-24-2008 07:59 AM
How do you add card reader drive letters in import directories? TechBill SageTV Software 11 11-13-2007 10:49 AM
Import Directories Francois Parent SageTV Software 1 02-26-2006 07:52 AM
