Old 12-02-2015, 09:09 PM
craigap craigap is offline
Question regarding "Archived" setting
I moved recordings around and changed directories etc. etc. with my Sagetv Recordings and now all of them have the "Archived" setting checked in them. Is there a way to "Unarchive" them without having to go in and manually uncheck it in each recording a thousand times?
Old 12-03-2015, 06:49 PM
Denali Denali is offline
SageTV Web Interface or Batch Metadata Tools Web Interface
HTPC: Gigabyte GA-Z170XP-SLI, I7-6700, 16GB, Windows 10 Pro x64, Hauppauge HVR-1600, WinTV-dualHD, Colossus 2, Samsung 850 EVO 120GB, Seagate 3TB, WD 3TB, 3TB, 5TB, Java v1.8.0_231, SageTVx64 v9.2.1.826, Samsung UN60EH6003F, Dish ViP222K, ViewHD 1x2 HDMI Splitter.
Old 12-03-2015, 06:54 PM
Use malore menus filter by archive group by single group. Select the number of archived recordings on the left.Then unarchive all.
Old 07-14-2016, 10:14 AM
Hatterasman Hatterasman is offline
Set/Clear All Archived
I know this is an old thread but I thought I'd post an easy solution in case anyone is looking...if you press the "info" button the the remote from the main recordings list you can set/clear all for watched, archive and don't like bits.
This works when there is more than one recording for given show and they are grouped by title in options.
Server: Gigabyte GA77Z-UDH5, i7 3770, 32GB DDR3, 4-port PCIE SATA card x2, Crucial 120 GB SSD x2 (raid 1 - OS), W10 Pro x64, 3TB x3, 6TB x4 (33 TB), 2TB x2 (raid 1 - data)
Capture: HDPVR x4, DTV H24D-700 x4, Http Ethernet Control x4
Clients: HD200 x 4, HD300 x1
Network:
Netgear 16-port Gigabit Switch, D-Link Wireless N Router
"Archived" shows re-appearing on recordings list? timg11 SageTV Software 24 11-27-2013 08:49 AM
Question about Sage TV, that "other brand" of "snappy" PVR software, and the HD-PVR Savage1701 SageTV Software 8 05-02-2009 06:59 AM
"Set defaults" for Series forgets "Keep"/"Auto-delete" setting maxpower SageMC Custom Interface 9 05-14-2008 09:44 PM
Empty "Archived Recordings" bug or not? marchold SageTV Beta Test Software 1 11-12-2006 10:06 PM
2.1.9/10 Problem - SageTV Recordings List Suddenly Empty ... moved to "Archived" ??? sudipto SageTV Software 3 11-04-2004 03:08 AM
