Old 03-30-2020, 08:03 AM
craigap craigap is offline
IR extender cable for HD300
I want one, but I wasn't sure if any of the ones I'm seeing on Amazon will work or not. Can anyone point me in the direction of an IR cable that I can use with the HD300?
Craig
Old 03-30-2020, 08:17 AM
Check out this thread: https://forums.sagetv.com/forums/showthread.php?t=56246
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i7-7700T CPU, 32GB Memory, unRAID 6.9.2, SageTV & OpenDCT Dockers
Tuners: 2 x SiliconDust HDHomeRun Prime Cable TV Tuners
Clients: Multiple HD300 Extenders, Multiple Fire TV Stick 4K w/MiniClient
Old 04-11-2020, 05:08 PM
Seems that most of the links in that thread are dead. However, I was able to take away a little info, and I decided to buy a cable from Amazon and see if it would work straight out of the box, or try to switch up the wires. I purchased this one and got it working by swapping the red and white wires.
https://www.amazon.com/uxcell-Infrar.../dp/B07FKMK3GZ
Craig
Old 04-11-2020, 05:41 PM
KryptoNyte's Avatar
Pretty slick, Craig. I built a cable a long time ago because my bedroom TV is sitting just under the dresser that the TV sits on. As it turns out, I found that if I keep the HD300 flush front face with the dresser it sits under, that I can just point my remote at the ceiling and still control without issue (even without the IR extender cable plugged in). If the HD300 were stuck to the back of the TV, it might not be so successful I suppose.
HD200 Remotes - HD 200 break out cable and HD300 Composite Cable heffneil SageTV Marketplace 0 10-08-2019 12:59 PM
HD300 Breakout Cable dinki SageTV Media Extender 0 09-03-2014 07:08 AM
For Sale: HD300 with remote, AV Cable & IR Extender Brent SageTV Marketplace 2 06-19-2013 03:14 PM
HD300 IR only works with the cable Rob SageTV HD Theater - Media Player 0 07-01-2011 10:26 AM
