Old 09-25-2006, 11:33 AM
mikejaner's Avatar
New Hauppauge ATSC USB2 Tuner: WinTV-HVR-950
http://www.hauppauge.com/pages/produ...ta_hvr950.html
Mike Janer
SageTV HD300 Extender X2
Old 09-25-2006, 01:13 PM
Kirby's Avatar
Kirby Kirby is offline
How are ATI's ATSC tuners? What chipset do they use?
One thing that makes me worry about this one, right from the getgo, they dont have a clue about what HD ATSC file sizes can be:
Record ATSC digital TV to your PC's hard disk using high quality MPEG-2. ATSC digital TV recordings will typically consume 4 Gb of disk space per hour.
Sage Server: HP ProLiant N40L MicroServer, AMD Turion II Neo N40L 1.5GHz Dual Core, 8GB Ram, WHS2011 64bit, Sage 7.1.9 WHS, HDHR (1 QAM, 1 OTA), HDHR Prime 3CC, HD-PVR for copy-once movie channels
HTPC Client:Intel DH61AG, Intel G620 cpu, 8GB ram, Intel 80GB SSD, 4GB RamDisk holding Sage/Java/TMT5
Sage Client:Sage HD-200 Extender
Old 09-25-2006, 01:41 PM
lobosrul's Avatar
lobosrul lobosrul is offline
I get typical file sizes of around 5.2 GB for 720p and 7.6 GB for 1080i, IIRC.
Old 09-25-2006, 01:52 PM
Kirby's Avatar
It all depends on your local affiliate and what they do with the signal. one of my local FOX HD's runs around 6.8GB/hour on 720p material, but the ABC is barely 6.0GB. I've had a CBS feed at almost 8GB per hour before they started to multicast a SD and weather channel.
I would really hate to have an affiliate that dumbed down the HD signal to only 4GB per hour.
Old 09-25-2006, 03:33 PM
chrisc16's Avatar
chrisc16 chrisc16 is offline
Hauppauge is referring to "ATSC digital TV recordings" - which could be SD or HD. So yes, HD recordings are usually much higher than 4GB/hour, but maybe if you average in SD recordings it's closer to their quoted figure.
-Chris
Win7, HDHomeRun, HD200
Old 09-25-2006, 03:48 PM
Any idea how much? That think would be sweet for debugging
Old 09-27-2006, 10:50 AM
flashbacck flashbacck is offline
Anyone used the new Hauppage WinTV-HVR-950 yet?
Just wondering if anyone has initial impressions about quality, software compability, etcetc...
edit: weird I swear I searched before posting.
Anyway, the MSRP is expected to be $100
C2D e6320
P4M800Pro, 1gb DDR, 1100GB HDs
Hauppauge HVR-1600, HDHomerun, Geforce 6200
