Old 06-23-2012, 06:58 AM
heatvent's Avatar
heatvent heatvent is offline
HDHomeRun Prime vs. DCR-2650 Channel Changing
I just got a HDHomeRun Prime up and running and have to say, I am a bit disappointed with the channel tuning speed. I feel like I want to get up and get a soda while waiting for the channel to tune in. I remember reading a post somewhere by someone that was very happy with the Hauppauge DCR-2650 speed. Is there anyone who has used both and can comment on the speed of one over the other.
SageTV 7.0.0.23, P5Q-EM Motherboard, 2.5Ghz Quad Core, Windows 7 x64, HVR-2250, 8GB RAM, 1TB HD, 2 HD-200 Extenders
Old 06-23-2012, 07:57 AM
I have the HDHomerun prime and the channel changes are almost instant ... very quick. I do have my 2 Hd Homerun Dual QAM tuners and my HD Homerun prime on its own gigabit Intel NIC. So that is a total of 7 Tuners on 1 Gigabit Nic with 8 port switch.
Old 06-23-2012, 10:49 AM
tmiranda's Avatar
tmiranda tmiranda is offline
My Prime changes channels almost instantly as well.
Old 06-23-2012, 01:34 PM
Same here-changes almost instantaneously. Make sure you're not seeing errors in the SageDCT error log.
Old 06-23-2012, 04:07 PM
phelme's Avatar
phelme phelme is offline
Mine is fast as well, but I do notice Sage tends to select a different tuner from the Prime than the one currently being used when changing.
Backup: Synology
SageTV version: FINAL
Old 06-23-2012, 04:08 PM
heatvent's Avatar
Thanks I will dig a little bit deeper. Probably just another case of user error.
Ceton or HDHomeRun Prime profit Hardware Support 10 04-01-2012 09:35 AM
Centon vs Prime vs 2650 which is more stable impro Hardware Support 6 09-11-2011 06:41 AM
Ceton and hdhomerun prime CADDYROGER Hardware Support 2 08-24-2011 05:38 AM
HDHomerun Prime? cenwesi Hardware Support 26 04-19-2011 05:40 PM
