Old 01-29-2004, 04:40 AM
nielm's Avatar
nielm nielm is offline
xmltv import and 'clumps'
It seems that the import plugin does not handle 'clumps' of programs very well -- these are when multiple programs share the same timeslot, which happens sometimes with RT grabber, eg:
last night: Film: Thirteenth Floor, followed by Weatherview...
This shows up in the XML output as two programs with the same timeslot but with clumpidx=0/2 and 1/2:
  <programme start="20040128232500 +0000"
      stop="20040129010500 +0000"
      channel="london.bbc1.bbc.co.uk"
      clumpidx="0/2">
    <title lang="en">The Thirteenth Floor</title>
  </programme>
      clumpidx="1/2">
    <title lang="en">Weatherview</title>
  </programme>
The XMLTV importer ignores this clumpidx and over-writes the first program with the second... Which meant I missed File 2004 on Wed, and 13th Floor last night -- they were both described as 'Weatherview!'.
A workaround is to use tv_grep to grep for non-clumped programs, and only the first program in each clump (which is usually the most important):
tv_grep --not --clumpidx "" -or --clumpidx "0/" data.xml > noclumps.xml
Old 05-27-2004, 03:40 AM
nielm's Avatar
Any moderators around, would it be possible to make this a 'sticky note' -- thanks!
Old 05-05-2006, 03:11 PM
StephaneM's Avatar
StephaneM StephaneM is offline
Just a quick note, if you use my Import plugin, the whole "tv_grep" thing is not needed. The Importer will correctly handle the "clumps", that is : retrieving the first show in the clump, and adding the other shows in the description of the first one.
Regards,
Stéphane.
