Old 12-15-2008, 06:49 PM
John@TunerUK John@TunerUK is offline
UI slowdown after file deletion
If I decide to have a bit of a tidy up of my tv recordings, I find I can't delete more than about 4 recordings without a severe slowdown of the UI. And the more I delete, the worse it gets. Ater deleting about 10 recordings I'll press a button, sage freezes, I then keep trying buttons just because I've convinced myself the next button will work. When I finally give up, if I just leave it alone for about 2-3 minutes, it suddenly springs into life and replays all the 20 or so buttons I pressed whilst I was waiting. Then a few button presses later it does the same.
The only way to fix it seems to be to restart sage (Just the player, not the service).
It only seems to affect the server, not the clients.
Anyone else have the same problem, and/or a possible fix?
I've searched the forum but not found any mention of it elsewhere.
Cheers
John
Antec Sonata III, Abit AN-M2HD, AMD 4200+, Thermalright SI-128 Cooler, 2GB OCZ DDR2, 2x500Gb + 1x1Tb Samsung Spinpoint SATA II, Hauppauge Nova-T500, Technotrend 3200-S2 with CI, Oasis II CAM. Windows XP Home SP3, Logitech Harmony 525. Logitech DiNovo Edge
STV Import: Read & Write Metadata files for Default STV 5/6 (v2.2.9 18/Feb./2010) JREkiwi SageTV Customizations 251 10-09-2019 11:11 AM
Searching File Format with WebUI megamojo SageTV Customizations 1 08-27-2008 04:37 AM
Allow file Deletion under File Browser Options question carlgar SageTV Software 1 06-17-2008 11:29 AM
Force Delete a File mike1961 SageTV Software 4 03-12-2007 11:52 PM
HDTV Network Encoder v0.9.0 07-08-05 - HD Support for Sage! Stealth1971 Hardware Support 292 02-23-2006 11:40 AM
