Old 12-15-2015, 02:27 PM
SidKnee SidKnee is offline
SageTV Open Source Version?
Hi,
Has anyone tried the new open source version of SageTV?
Cheers,
Adrian.
Old 12-15-2015, 03:03 PM
HelenWeathers's Avatar
I updated to the latest version a few days ago. Running fine on my Win 10 server.
Old 12-16-2015, 01:56 AM
rickgillyon's Avatar
Been using it for months. Working well.
Old 12-16-2015, 03:43 PM
That's good to hear. I've not looked into it in any real detail yet but (other than the lack of licensing) what improvements/benefits have you seen?
Cheers,
Adrian
Old 12-16-2015, 04:18 PM
I think the only functional benefit is the new Youtube plugin only supports progressive downloading with V9.
Old 12-17-2015, 07:46 AM
tmiranda's Avatar
tmiranda tmiranda is offline
If you are using Linux you can run the 64 bit version and have a bigger Java heap.
Old 12-18-2015, 02:20 PM
Thanks, early days yet then (I'm not an early adopter - the family would kill me!) but sounds promising.
Cheers,
Adrian.
Old 06-14-2016, 07:21 AM
emotionnotion emotionnotion is offline
I upgraded and it did not work properly with Gemstone on my Windows Home Server. Tried a separate Windows 10 machine; no issues.
If you have an older version of Windows I would steer clear right now.
Server: Tranquil T7 Intel Atom D330, 2GB RAM, Windows Home Server, Sage TV 7.1.9 (Last version ever ), 2 HDHomeruns tuning 4 OTA channels, Sony 32EX490 Bravia LCD
Clients: 3 HD300s, 2 HD200s, 1 PS3
Old 06-14-2016, 08:58 AM
v9 also has some database improvements (quite a bit faster, and far fewer spinning circle waits).
SageTV is Open Source!!! Narflex Announcements 1 01-12-2016 10:36 AM
Odd Weather Info Issue (not sure if it's related to the Open Source version or not) stuckless SageTV Github Development 2 10-08-2015 04:50 AM
Should I use the open source version now? gacevich SageTV Github Development 9 08-17-2015 01:23 PM
SageTV Open Source Narflex Announcements 0 03-09-2015 02:39 PM
