QAM No Signal
I ran the scan for QAM on my Charter Cable Service (Fort Worth, TX) and it came up with 15 or so channels but all of them when I select "View" have "No Signal".
Did I do something wrong or am I just all excited about having some QAM channels and really don't have any ![]()
System (Windows Vista Ultimate): AMD Athlon 64 3500 / BFG Tech NF4S (nForce4 Ultra) / 4GB PC3200 / Sapphire ATI 2400PRO (Passive) Drives: 2x 500gb Seagate 7200.10 (Mirrored) / 1x NEC DVD-R/W PCI Cards: 1x Hauppauge PVR 150 & 1x Hauppauge HVR 1600 Remote: Media Center Remote / Keyboard Case: MCE-701 w/ 7-Inch Touchscreen |
Did you do he scanning with your TV? If not you should that first.
What do you mean by "With your TV"? I loaded up the WinTV 418 TS Source and then hit "Scan For Available Channels"
And as we speak I updated the Hauppauge drivers and it worked ![]() Thanks for replying though ![]()
Excellent. You could hook your TV directly to the cable outlet and let it scan for channels. Without the cable box it will only be 'seeing' non-encrypted stuff, just like the HDHR will.
That's how I have it pluggin in (no cable box)
![]() Now I just need to figure out the stutter problem... ![]()
Get QAM Content with your existing QAM capture cards! | Stealth1971 | General Discussion | 172 | 02-02-2008 05:58 PM |
HVR-1600 No signal issue | Endymion | Hardware Support | 7 | 09-16-2007 02:24 PM |
HDHomeRun QAM Audio/Video hickups on certain channels at certain times | mkanet | Hardware Support | 4 | 07-09-2007 07:18 PM |
Stutter/Jitter using A180/Vbox and OTA? Check signal "Strength" not "quality" | svemuri | Hardware Support | 0 | 12-13-2005 10:51 AM |
