Old 07-30-2021, 05:55 PM
Video Import Bug
I imported a video into SageTV. Because it is an mkv file, it will not play in the HD300, but it played fine with the mini-client. Well almost. The playback stops before the video is finished.
When I look at the video details it says it is 44 minutes long. Yet when I use MediaInfo on the file, it is 57 minutes and 40 seconds.
Take a look at the attached image. I have never seen this type of problem before.
Servers: ChannelsDVR, Plex, AnyStream, PlayOn,
Tuner: HDHomeRun Connect Duo
Sources: OTA, Sling Blue, Prime, Disney+,
Old 07-30-2021, 06:09 PM
trk2 trk2 is offline
AVC and AAC should playback correctly in a MKV container on a HD300. Does it playback completely on another player (VLC)?
Old 07-31-2021, 03:41 AM
It plays back fine in VLC and Plex.
Old 07-31-2021, 06:06 AM
jvl711's Avatar
jvl711 jvl711 is offline
Did you try my media format plugin or sagetvtranscoder plugin. Both of them use a much newer version of FFmpeg than core sage to detect the media.
Projects I am currently maintaining
SageTV Andoid Client
Media Format Parser Plugin
JavaFFmpegLibrary
SageTVTranscoder
If you like the work I am doing and would like to support it you can become a Patreon member.
Old 07-31-2021, 08:38 AM
Not sure that would help. The length was set when it was imported.
Old 07-31-2021, 10:23 AM
wnjj wnjj is offline
Ffmpeg is used when importing to detect the length.
Windows Installer
Old 08-01-2021, 07:47 AM
I used the web interface to change the length to an hour.
Video Import Folder ldl72 Gemstone for v7 7 10-17-2012 03:52 AM
Import video from c:\ keeps getting added bjwise96 SageTV Software 5 09-19-2009 08:36 AM
UNC import video issue matt91 SageTV Software 7 09-04-2007 03:15 PM
Video Import? Todd3835 SageTV Software 5 05-31-2007 01:54 AM
