Old 11-11-2005, 08:52 AM
Soulive Soulive is offline
Hauppauge IR Blaster
After a upgrade to the newest pvr150 drivers, including a reinstall of IR Remote and IR Blaster, SageTV4 no longer works with the IR Blaster stub device. IR Remote works fine in Sage. BlasterConfig works fine in powering on/off and tuning the channel of my Dish box. Sage is configured to use the Hauppauge IR stub device. I also choose to reinstall SageTV4 using the repair option with no effect. Any thoughts?
Old 11-15-2005, 10:12 PM
LazyGun LazyGun is offline
I am having the same issue...since the upgrade the 45 button remote is not working with Sage.exe -client.
It magically worked last night, when I got the end of a recording, but since then has not worked again...and I have no idea why/what/how.
Old 11-16-2005, 08:46 AM
I did a complete reinstall. It fixed the problems I was having. Another benefit of the reinstall was it cleaned up alot of old STV entries in sage.properties from 2.2.8 when I was trying out many different STVs. Back to workin' perfectly.
-Soulive
Old 11-16-2005, 11:35 AM
Hey, thanks for replying and letting me know. I will give that a try this evening. Although this will be my 2nd reinstall (first since the IR broke though ).
Cheers
