Old 02-17-2006, 06:04 PM
lovingHDTV's Avatar
Recommended way to setup ac3filter to spdif out?
What is the SageTV recommended way to setup the included ac3filter to use spdif passthrough? I find that I have to download filter graph, render a video file, right click, hit properties and set it there. This is becuase the included filter from Sage does not include the configuration tool, nor provide a means to configure it from within Sage.
I can't imagine this is what is expected for all users to do?
thanks,
Old 02-17-2006, 08:21 PM
Fluffdaddy Fluffdaddy is offline
Make your life e-z
Buy Nvidia Purevideo encoders which includes an easy spdif configuration tool....................... In out Done !
test it out for free
Old 02-17-2006, 08:22 PM
lovingHDTV's Avatar
I have bought the encoders, where is this config tool?
thanks,
Old 02-17-2006, 08:27 PM
Are you feeding it into a receiver? Do you have Windows Media Player 10 installed? If so, open it up, go into the Tools menu and select "Options..." This will open up a window for you with a bunch of tabs across the top. Select the DVD tab. You want the Advanced tab at the bottom. For me, at least, using the NVidia decoders, this will open up a configuration screen for the audio decoder. It contains a speaker setup menu that allows you to select speaker type Receiver" and a checkbox for Output using S/PDIF cable. You should be good to go after that
Old 02-17-2006, 08:28 PM
lovingHDTV's Avatar
Thanks, I'll take a look, did not think to look inside WMP.
Old 04-04-2006, 01:30 PM
Dekard's Avatar
Dekard Dekard is offline
I've done this but I'm still not getting 5.1 from my spdif output. I've tried the version of the purevideo on the cd I got from pc alchemy, 1.0.5? and I've tried the latest versions downloaded from the internet. I notice if I play a dvd with the intervideo windvd 7 I get 5.1 to my receiver but not playing the same dvd using wmp or sage. Thoughts?
www.overclockingwiki.org
