Old 08-19-2006, 09:44 PM
sticky sticky is offline
Dual server and dual client Setup
Here is the dealio.
I will have a Sage Server in my office hooked up to two Dish Network boxes, a Sage Server in the living room hooked up to my TV with two OTA HDTV cards and a few clients across the house. I have to have the the OTA cards in the living room because I can not tune OTA in my office.
Would this type of configuration work. I believe the OTA Server would act as a network encoder, but would the two servers "sync up" and would the client be able to tell either server to record?
Old 08-19-2006, 09:56 PM
If you set up one of the servers as a network encoder, as shown on the bottom half of p. 248 of the v5.0 manual (Appendix G), you'll have a single SageTV system to share for all your clients. (The network encoder system would have a UI that acts as a client of the main server too.)
If you want, you could also set up your recording dirs as UNC paths, then use the mmc/encoders/###/forced_video_storage_path_prefix= property to have the tuners in each system store their recordings on the local system. Just use the first few chars of the UNC path that is local to a tuner to have it use only those dir(s).
Old 08-20-2006, 11:59 AM
Andy,
Thanks for the help . Now to wait for the upcoming beta . Does my status of EX-news guy get me a sneak peak at the beta .
Regards,
Alan
AKA sticky
Old 08-20-2006, 12:32 PM
I don't know, but that would be news to me...
Old 08-22-2006, 09:51 PM
On the netwrok encoder machine.. does that require two licenses? One for the network encoder and one for the client?
Old 08-22-2006, 09:57 PM
No, the encoder only needs a license for SageTV, since it acts as both the encoder and client UI. The first bullet-point on p. 248 tells how to start a client UI.
(edited to correct the answer)
Old 08-24-2006, 02:25 AM
korben_dallas's Avatar
korben_dallas korben_dallas is offline
Question
Yes, they are two separate installations of SageTV & each license is for use on a single PC.
Are you contradicting yourself, Andy? If he purchases a full version of SageTV, which comes with recording and playing ability, why would he need an additional client license if that full version is used as a network encoder?
SageTV server & client: Win 10 Pro x64, Intel DH67CF, Core i5 2405s, 8 GB ram, Intel HD 3000, 40GB SSD system, 4TB storage, 2x HD PVR component + optical audio, USB-UIRT 2 zones + remote hack, Logitech Harmony One, HDMI output to Sony receiver with native Intel bitstreaming
Old 08-24-2006, 08:51 AM
Oops! Thanks, I misread the question & thought the question was whether 2 SageTV licenses were needed for the 2 PCs.
On the encoder PC, only a SageTV license is needed; the additional Client license is not needed for that PC since SageTV acts as both the encoder and the client UI. I'll edit my above post to correct it also.
