Old 01-14-2009, 10:29 AM
ace007 ace007 is offline
HDPVR questions
I'm looking to buy an HDPVR to use to get the encrypted channels from my Comcast HD cable box in to Sage. I have a few questions hopefully somebody can help with.
1. How well does it appear to work with Comcast HD STBs?
2. Is there any type of power control to turn off the Comcast STB and/or the HDPVR when Sage does not need to use it.
3. Are there any specific hardware models to the HDPVR to avoid?
4. Is there a good guide here on how to setup the HDPVR to work well with Sage?
5. Wanted to add another question.. I'm running sage on Vista x64 so from my research I cannot change the channel on my Comcast Cable box via Firewire. What other options do I have to change the channel or can the HDPVR do that for me?
Robert
Old 01-14-2009, 10:48 AM
ghostlobster's Avatar
ghostlobster ghostlobster is offline
Send a message via MSN to ghostlobster
It'll work fine with nearly any cable box. It's just grabbing the same analog signal from the component output that your HDTV would use.
No...not that I know of.
The jury is out on this one. Basically, make sure that you can RMA it just in case you get a lemon.
Actually, the setup is pretty easy. Just install the HD-PVR CD, select your options and it'll work.
The HD-PVR has an integrated IR blaster which works with SageTV. You should be OK, though I'm not certain about the 64bit issue.
Ghostlobster
Server: Athlon 3000+, 1GB RAM, 2 Hauppauge 150s, HDHomeRun, HD-PVR driving 3 clients.
Client 1 - Athlon 4600 x2, 2 GB RAM, ATI HD2600 XT
Client 2 - Athlon 4200 x2, 1 GB RAM, ATI HD2400 Pro
Client 3 - Athlon 4200 x2, 1 GB RAM, nVidia 8500 GT
Raleigh Computer Repair
Old 01-14-2009, 06:42 PM
ThePaladinTech's Avatar
ThePaladinTech ThePaladinTech is offline
While that is true I think you want to get at least a C2 model? I have a C2 and it seems to be working fine, So I think what Ghostlobster meant was the jury is out on which model is guaranteed to work, but I think it's generally agreed that Rev C and earlier do not work well at all. They are currently at Rev E1 or E2 ...
(current) SageServer: SageTV Open Source V9 - Virtual Ubuntu on Win10 HyperV MSI 970A-G46, AMD FX-8370 , SD Prime via OpenDCT, Donater ComSkip
Clients: HD-200, Nexus Player w/ Android miniclient
Storage: "nas" 16 drive Win10 w/ DrivePool running Plex, Emby, & SD PVR
Retired - Hava, MediaMVP, HD-100, HD-PVR, HVR-2250, Ceton InfiniTV4, Original (white) HDHomeRun Died - HD-100, HD-300
Must the HDPVR be directly attached to Sage Server? Ron Hardware Support 8 02-18-2009 04:16 PM
"Best" settings for a HDPVR zoltran Hardware Support 3 01-09-2009 04:24 PM
How are 2 HDPVR setups running. Thinking about adding a 2nd. sagepower Hardware Support 3 01-08-2009 01:42 PM
Sage HD Theater of Media Extender Questions TheraEdge SageTV Media Extender 4 12-09-2008 10:02 AM
Bad HDPVR or some other issue? pat_smith1969 Hardware Support 5 10-20-2008 01:09 PM
