Old 04-04-2011, 07:36 AM
ChrisHill ChrisHill is offline
Cinergy T PCIe Dual
Has anyone got/used on of these?
http://www.terratec.net/en/products/...en_141643.html
I have a 2400DT which has been great but seems to have intermittent problems when one or the other tuner breaks on it. (I think it is a hardware issues as it did it on an XP and Windows 7 computer). So I am looking at a replacement. Its either this or go for the BlackGold HD duel tuner but that doesnt seem to be well supported yet by sage.
Any suggestions, thanks in advance.
Old 04-05-2011, 01:48 AM
rickgillyon's Avatar
Yes, I had periodic failures with Terratec too. Would disable one of the tuners from time-to-time when it played up, then re-enable it later. Haven't used the new version.
Did you see this thread - these Kworld tuners are working pretty well, and you can probably get three for the price of one of the Terratecs.
unRAID Server: Intel Core i5 7600K, 16GB DDR4, 2x512GB PCIe M.2 Cache Pool, 2x4TB SATA3 Parity Drive, 2x3TB + 1x4TB SATA Array, 1x TBS 6284 PCIe DVB-T2 Quad, 2x TBS 6205 PCIe DVB-T Quad, Cable TV from TBS2603 sat/IP, IPTV via Telly & node-ffmpeg-mpegts-proxy, unRAID 6.6.6, TVheadend for recording back end, OpenDCT, SDEPG, SageTV 9
Clients: 3 Nvidia Shields, 2 Android Miniclients (Amlogic S905X), 3 Win10 Pro PC Clients
Old 04-09-2011, 08:12 AM
Thanks for that I am going to order one now 20 you can't go far wrong.
Old 04-15-2012, 08:42 AM
doc doc is offline
Glad I found this thread.
I noticed some recording errors a few months back on my 2400i card. I put my old nova-t-500 in and its been fine since.
I decided to play with the card today to do some retuning, and found that tuner 2 works fine, but tuner 1 doesn't work at all.
I was thinking it's something I've messed up, but it looks like a common fault.
It's a shame, but it'll do in the test pc as long as I remember which tuner doesn't work.
PCIE dual tuner card with COMPONENT in and DIVX hardware capture!!! antisoshal Hardware Support 15 01-07-2010 10:48 AM
Dual Digital OTA PCI/PCIe card? CanadianEh Hardware Support 2 08-22-2008 12:08 PM
Lost 2nd Tuner on terratec cinergy dual tuner michaeldjcox Hardware Support 2 07-10-2007 01:57 AM
What's the highest quality dual tuner PCIe card? mkanet Hardware Support 11 05-31-2007 03:33 PM
vBox dual tuner HDTV PCIe (Cat's Eye e154) coming first quarter ToxMox Hardware Support 3 01-26-2006 10:58 AM
