Old 08-28-2016, 10:43 AM
Unhappy OpenDCT not finding HDHomeRun Tunners
Here is what I did:
Stopped and disabled SageDCT
Stopped SageTV Service
Made Backup Copy of Sage.properties and Wiz.bin.
Installed OpenDCT
Ran "OpenDCT Run as Console".
CTRL-C on OpenDCT after UPnP discovery thread has stopped message.
Ran "OpenDCT Start Service"
changed network_encoder_discovery=false to true.
Started SageTV Service
Started SageTV
Setup>Setup Video Sources>Add New Source.
The only Video sources I see are the SageDCT tuners, nothing from OpenDCT
What am I doing wrong?
#OpenDCT Configuration File
#Sun Aug 28 12:40:45 EDT 2016
channels.qam.automap_reference_lookup=true
channels.qam.automap_tuning_lookup=true
channels.update=true
consumer.ffmpeg.enhanced_logging=true
consumer.ffmpeg.limit_logging=true
consumer.ffmpeg.linux_logging=true
consumer.ffmpeg.log_stream_details_for_all_programs=false
consumer.ffmpeg.thread_rename_logging=false
discovery.devices.exp_always_enable=true
discovery.devices_permitted=
discovery.exp_enabled=true
hdhr.allow_http_tuning=true
hdhr.allow_qam_http_tuning=true
hdhr.always_tune_legacy=false
hdhr.broadcast_port=64998
hdhr.broadcast_s=58
hdhr.discoverer_enabled=true
hdhr.exp_ignore_models=
hdhr.extend_transcode_profile=
hdhr.ignore_device_ids=
hdhr.locking=true
hdhr.offline_detection_min_bytes=10528
hdhr.retry_count=2
hdhr.smart_broadcast=true
hdhr.wait_for_offline_detection_s=8
hdhr.wait_for_streaming=15000
log.min_free_space=1073741824
log.remove_after_days=30
pm.enabled=true
pm.network.resume_timeout_ms=120000
pm.network.start_retry=120
pool.enabled=false
producer.rtp.nio.native_udp_receive_buffer=5312000
sagetv.device.global.ignore_devices_csv=
sagetv.device.global.only_devices_csv=
sagetv.device.global.required_devices_loaded_count=0
sagetv.device.global.required_devices_loaded_timeout_ms=30000
sagetv.device.parent.1279436506.device_name=HDHomeRun DRI Tuner 1311D58D
sagetv.device.parent.1279436506.local_ip_override=
sagetv.device.parent.1286496744.device_name=HDHomeRun DRI Tuner 13199518
sagetv.device.parent.1286496744.local_ip_override=
sagetv.early_port_assignment=false
sagetv.encoder_discovery_port=8271
sagetv.new.default_consumer_impl=opendct.consumer.FFmpegTransSageTVConsumerImpl
sagetv.new.default_transcode_profile=
sagetv.new.device.default_encoder_merit=0
sagetv.new.device.default_tuning_delay=0
sagetv.new.device.increment_port=false
sagetv.new.device.socket_server_port_high=9100
sagetv.new.device.socket_server_port_low=9001
sagetv.new.device.socket_server_shared_port=9000
sagetv.use_automatic_loopback=true
upnp.dct.fast_tuning=false
upnp.dct.hdhr_tuning=true
upnp.dct.http_tuning=true
upnp.dct.wait_for_streaming=15000
upnp.enabled=true
upnp.exp_legacy_capture_device=true
upnp.new.device.schema_filter_strings_csv=schemas-cetoncorp-com
upnp.new.device.search_interval_s=4
upnp.new.device.search_strings_csv=schemas-cetoncorp-com,schemas-dkeystone-com
upnp.qam.automap_reference_lookup=true
upnp.qam.automap_tuning_lookup=false
upnp.service.configuration.http_listen_port=8501
upnp.service.configuration.ignore_interfaces_csv=
upnp.service.configuration.ignore_local_ip_csv=
upnp.service.configuration.use_dct=true
version.config=4
version.program=0.4.49
Server: Intel Core i5-3330 CPU @3.00GHz; 8GB (2 x 4GB) PC3-12800 DDR3 1600MHz; 3-1TB WD Blue SATA 6.0Gb/s 64 MB Cache 7200RPM HDD; Windows 7; SageTV 9
Tuner: (2) HDHomeRun Prime
Client: HD300; Onkyo TX-SR607; Sony XBR-65X850D
Client: HD300; Samsung UN46B7000
Client: Nexus Player / Mini-Client; Sony KDL-32L4000
Client: SageTV Placeshifter 7
Client: SageTV Client 9
Old 08-28-2016, 02:32 PM
KryptoNyte's Avatar
Just for the heck of it, restart the computer if you haven't already, and give it another shot.
You do have all the latest HDhomerun software installed?
Old 08-28-2016, 02:54 PM
Already tried restarting the computer with no luck.
Actually the HDHomeRun software is from 2014 since I was using SageDCT. Do you think that is it?
John
Old 08-28-2016, 03:04 PM
sic0048 sic0048 is offline
PHP Code:
Needs to be changed to the number of tuners you expect opendct to find.
You may also need to increase the timeout (next line down) from 30000ms to 60000ms or even 90000ms if the shorter times don't seem to work.
SageTV v9 (32bit)
Ceton InfiniTV ETH 6 cable card tuner (Charter cable)
OpenDCT
HD-100 HD Extenders
HD-300 HD Extenders
Nvidia Shield using the MiniClient
Using CQC to control it all
Old 08-28-2016, 04:54 PM
EnterNoEscape's Avatar
My first thought is firewall issues. Are you running anything other than the Windows firewall? If not, you might be able to help us out best by posting your opendct.log file. The logs should show if there are any issues with getting the right network adapters, bad replies, etc.
Old 08-28-2016, 05:26 PM
Log file attached.
17:39:57.500 [WrapperSimpleAppMain] INFO  Main - Starting OpenDCT 0.4.49...
17:39:57.531 [WrapperSimpleAppMain] DEBUG Config - OSVersion is parsing the name 'Windows 7'.
17:39:57.531 [WrapperSimpleAppMain] DEBUG Config - OSVersion determined that 'Windows 7' is WINDOWS.
17:39:57.562 [WrapperSimpleAppMain] INFO  Main - OpenDCT logging to the directory 'c:/ProgramData/OpenDCT/logs'.
17:39:57.562 [WrapperSimpleAppMain] INFO  UpnpManager - Logging Cling UPnP to 'c:/ProgramData/OpenDCT/logs\opendct_cling.log'.
17:39:57.562 [WrapperSimpleAppMain] DEBUG UpnpManager - Logging level for Cling UPnP is set to 'severe'.
17:39:57.562 [FFmpegAsyncInit-20] INFO  Main - FFmpeg loading...
17:39:57.656 [WrapperSimpleAppMain] INFO  NetworkPowerEventManger - Network interfaces which are up and have an IP4 address are:
name:eth6 (Realtek PCIe GBE Family Controller) 192.168.1.25
17:39:57.656 [WrapperSimpleAppMain] DEBUG WindowsPowerMessagePump - 'class opendct.power.NetworkPowerEventManger' is now listening.
17:39:57.656 [WrapperSimpleAppMain] DEBUG WindowsPowerMessagePump - 'class opendct.sagetv.SageTVManager' is now listening.
17:39:57.656 [WindowsPowerMessagePump] INFO  WindowsPowerMessagePump - Message pump started.
17:39:57.671 [SageTVDevicesLoaded-26] INFO  SageTVDevicesLoaded - Waiting for all capture devices to become available...
17:39:57.671 [WrapperSimpleAppMain] INFO  UpnpManager - Starting UPnP services...
17:39:57.749 [WrapperSimpleAppMain] INFO  DCTDefaultUpnpServiceConfiguration - Using the interface 'eth6' with IP address 192.168.1.25 for UPnP discovery.
17:39:57.765 [WrapperSimpleAppMain] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-cetoncorp-com' devices...
17:39:57.780 [WrapperSimpleAppMain] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-dkeystone-com' devices...
17:39:57.780 [WrapperSimpleAppMain] DEBUG WindowsPowerMessagePump - 'class opendct.tuning.upnp.UpnpManager' is now listening.
17:39:57.780 [UPnPDiscovery-34] INFO  UpnpManager - UPnP discovery thread has started.
17:39:57.905 [WrapperSimpleAppMain] DEBUG Config - OSVersion is parsing the name 'Windows 7'.
17:39:57.905 [WrapperSimpleAppMain] DEBUG Config - OSVersion determined that 'Windows 7' is WINDOWS.
17:39:58.092 [WrapperSimpleAppMain] DEBUG WindowsPowerMessagePump - 'class opendct.tuning.discovery.DiscoveryManager' is now listening.
17:39:58.092 [HDHomeRunDiscoverySend-38] INFO  HDHomeRunDiscovery - HDHomeRun discovery sender thread started.
17:39:58.108 [HDHomeRunDiscoverySend-38] INFO  HDHomeRunDiscovery - Broadcasting HDHomeRun discovery packet to /192.168.1.255:65001...
17:39:58.108 [HDHomeRunDiscoveryReceive-38] INFO  HDHomeRunDiscovery - HDHomeRun discovery receive thread for /192.168.1.255:65001 broadcast started.
17:39:58.108 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunControl - key: '/sys/hwmodel' value: 'null' lockKey: '0' sendLength: 23
17:39:58.108 [HDHomeRunDiscoveryReceive-38] INFO  HDHomeRunDiscoverer - Discovered a new HDHomeRun device 'HDHomeRun DRI Tuner 1311D58D'.
17:39:58.233 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.71, deviceId=319935885}
17:39:58.233 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunControl - key: '/sys/hwmodel' value: 'null' lockKey: '0' sendLength: 23
17:39:58.233 [HDHomeRunDiscoveryReceive-38] INFO  HDHomeRunDiscoverer - Discovered a new HDHomeRun device 'HDHomeRun DRI Tuner 13199518'.
17:39:58.280 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.72, deviceId=320443672}
17:39:58.311 [HDHomeRunDiscoverySend-38] INFO  HDHomeRunDiscovery - Broadcasting HDHomeRun discovery packet to /192.168.1.255:65001...
17:39:58.311 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.71, deviceId=319935885}
17:39:58.311 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.72, deviceId=320443672}
17:39:58.514 [HDHomeRunDiscoverySend-38] INFO  HDHomeRunDiscovery - Broadcasting HDHomeRun discovery packet to /192.168.1.255:65001...
17:39:58.514 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.72, deviceId=320443672}
17:39:58.514 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.71, deviceId=319935885}
17:39:58.576 [FFmpegAsyncInit-20] INFO  Main - FFmpeg loaded in 1014ms.
17:39:58.763 [cling-9] DEBUG RegisterDevice - Checking if the schema 'schemas-dkeystone-com' can be used...
17:39:59.169 [cling-9] DEBUG RegisterDevice - Checking if the schema 'schemas-dkeystone-com' can be used...
17:40:01.781 [UPnPDiscovery-34] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-cetoncorp-com' devices...
17:40:01.781 [UPnPDiscovery-34] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-dkeystone-com' devices...
17:40:03.217 [HDHomeRunDiscoverySend-38] INFO  HDHomeRunDiscovery - Broadcasting HDHomeRun discovery packet to /192.168.1.255:65001...
17:40:03.217 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.72, deviceId=320443672}
17:40:03.217 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.71, deviceId=319935885}
17:40:05.739 [cling-11] DEBUG RegisterDevice - Checking if the schema 'schemas-upnp-org' can be used...
17:40:05.781 [UPnPDiscovery-34] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-cetoncorp-com' devices...
17:40:05.783 [UPnPDiscovery-34] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-dkeystone-com' devices...
17:40:07.917 [HDHomeRunDiscoverySend-38] INFO  HDHomeRunDiscovery - Broadcasting HDHomeRun discovery packet to /192.168.1.255:65001...
17:40:07.917 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.72, deviceId=320443672}
17:40:07.917 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.71, deviceId=319935885}
17:40:09.783 [UPnPDiscovery-34] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-cetoncorp-com' devices...
17:40:09.783 [UPnPDiscovery-34] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-dkeystone-com' devices...
17:40:12.617 [HDHomeRunDiscoverySend-38] INFO  HDHomeRunDiscovery - Broadcasting HDHomeRun discovery packet to /192.168.1.255:65001...
17:40:12.617 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.72, deviceId=320443672}
17:40:12.617 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.71, deviceId=319935885}
17:40:13.783 [UPnPDiscovery-34] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-cetoncorp-com' devices...
17:40:13.783 [UPnPDiscovery-34] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-dkeystone-com' devices...
17:40:17.318 [HDHomeRunDiscoverySend-38] INFO  HDHomeRunDiscovery - Broadcasting HDHomeRun discovery packet to /192.168.1.255:65001...
17:40:17.318 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.72, deviceId=320443672}
17:40:17.318 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.71, deviceId=319935885}
17:40:17.784 [UPnPDiscovery-34] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-cetoncorp-com' devices...
17:40:17.784 [UPnPDiscovery-34] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-dkeystone-com' devices...
17:40:21.784 [UPnPDiscovery-34] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-cetoncorp-com' devices...
17:40:21.784 [UPnPDiscovery-34] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-dkeystone-com' devices...
17:40:22.018 [HDHomeRunDiscoverySend-38] INFO  HDHomeRunDiscovery - Broadcasting HDHomeRun discovery packet to /192.168.1.255:65001...
17:40:22.018 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.71, deviceId=319935885}
17:40:22.018 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.72, deviceId=320443672}
17:40:25.784 [UPnPDiscovery-34] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-cetoncorp-com' devices...
17:40:25.784 [UPnPDiscovery-34] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-dkeystone-com' devices...
17:40:26.718 [HDHomeRunDiscoverySend-38] INFO  HDHomeRunDiscovery - Broadcasting HDHomeRun discovery packet to /192.168.1.255:65001...
17:40:26.718 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.71, deviceId=319935885}
17:40:26.718 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.72, deviceId=320443672}
17:40:29.784 [UPnPDiscovery-34] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-cetoncorp-com' devices...
17:40:29.784 [UPnPDiscovery-34] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-dkeystone-com' devices...
17:40:31.424 [HDHomeRunDiscoverySend-38] INFO  HDHomeRunDiscovery - Broadcasting HDHomeRun discovery packet to /192.168.1.255:65001...
17:40:31.424 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.72, deviceId=320443672}
17:40:31.424 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.71, deviceId=319935885}
17:40:33.795 [UPnPDiscovery-34] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-cetoncorp-com' devices...
17:40:33.795 [UPnPDiscovery-34] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-dkeystone-com' devices...
17:40:36.135 [HDHomeRunDiscoverySend-38] INFO  HDHomeRunDiscovery - Broadcasting HDHomeRun discovery packet to /192.168.1.255:65001...
17:40:36.135 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.71, deviceId=319935885}
17:40:36.135 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.72, deviceId=320443672}
17:40:37.804 [UPnPDiscovery-34] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-cetoncorp-com' devices...
17:40:37.804 [UPnPDiscovery-34] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-dkeystone-com' devices...
17:40:40.846 [HDHomeRunDiscoverySend-38] INFO  HDHomeRunDiscovery - Broadcasting HDHomeRun discovery packet to /192.168.1.255:65001...
17:40:40.846 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.72, deviceId=320443672}
17:40:40.846 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.71, deviceId=319935885}
17:40:41.813 [UPnPDiscovery-34] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-cetoncorp-com' devices...
17:40:41.813 [UPnPDiscovery-34] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-dkeystone-com' devices...
17:40:45.557 [HDHomeRunDiscoverySend-38] INFO  HDHomeRunDiscovery - Broadcasting HDHomeRun discovery packet to /192.168.1.255:65001...
17:40:45.557 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.71, deviceId=319935885}
17:40:45.557 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.72, deviceId=320443672}
17:40:45.822 [UPnPDiscovery-34] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-cetoncorp-com' devices...
17:40:45.822 [UPnPDiscovery-34] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-dkeystone-com' devices...
17:40:49.832 [UPnPDiscovery-34] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-cetoncorp-com' devices...
17:40:49.832 [UPnPDiscovery-34] DEBUG UpnpManager - Sending a SecureContainer search message for 'schemas-dkeystone-com' devices...
17:40:50.268 [HDHomeRunDiscoverySend-38] INFO  HDHomeRunDiscovery - Broadcasting HDHomeRun discovery packet to /192.168.1.255:65001...
17:40:50.268 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.72, deviceId=320443672}
17:40:50.268 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Parsed discovery packet: HDHomeRunDevice{ipAddress=/192.168.1.71, deviceId=319935885}
17:40:51.501 [SageTVManagerShutdown] INFO  Main - Stopping all SageTV socket servers...
17:40:51.501 [ChannelManagerShutdown] INFO  Main - Stopping all channel update threads...
17:40:51.501 [DiscoveryManagerShutdown] INFO  Main - Stopping device discovery services...
17:40:51.501 [DiscoveryManagerShutdown] INFO  DiscoveryManager - Stopping discovery for HDHomeRun.
17:40:51.501 [Shutdown] INFO  Main - OpenDCT has received a signal to stop.
17:40:51.501 [Shutdown] INFO  Main - Saving current configuration...
17:40:51.501 [UpnpManagerShutdown] INFO  Main - Stopping UPnP services...
17:40:51.501 [PowerMessageManagerShutdown] INFO  Main - Stopping power messages...
17:40:51.501 [PowerMessageManagerShutdown] INFO  WindowsPowerMessagePump - Posting WM_QUIT message and waiting for message pump thread to exit.
17:40:51.501 [UpnpManagerShutdown] DEBUG DCTRegistryListener - Before shutdown, the registry has 3 device(s).
17:40:51.501 [WindowsPowerMessagePump] INFO  WindowsPowerMessagePump - Message pump stopped.
17:40:51.501 [UpnpManagerShutdown] DEBUG DCTRegistryListener - Shutdown of registry complete.
17:40:51.501 [HDHomeRunDiscoverySend-38] DEBUG HDHomeRunDiscovery - Interrupted while waiting for next broadcast to be sent => java.lang.InterruptedException: sleep interrupted
	at java.lang.Thread.sleep(Native Method)
	at opendct.tuning.hdhomerun.HDHomeRunDiscovery.run(HDHomeRunDiscovery.java:241)
	at java.lang.Thread.run(Unknown Source)
17:40:51.501 [HDHomeRunDiscoveryReceive-38] DEBUG HDHomeRunDiscovery - Channel was closed while receiving HDHomeRun discovery packets from [/192.168.1.255:65001] => java.nio.channels.ClosedByInterruptException
	at java.nio.channels.spi.AbstractInterruptibleChannel.end(Unknown Source)
	at sun.nio.ch.DatagramChannelImpl.receive(Unknown Source)
	at opendct.tuning.hdhomerun.HDHomeRunDiscovery$ReceiveThread.run(HDHomeRunDiscovery.java:281)
17:40:51.501 [DiscoveryManagerShutdown] INFO  DiscoveryManager - HDHomeRun discovery stopped.
17:40:51.501 [UPnPDiscovery-34] INFO  UpnpManager - UPnP discovery thread was interrupted => java.lang.InterruptedException: sleep interrupted
	at opendct.tuning.upnp.UpnpManager$1.run(UpnpManager.java:140)
17:40:51.501 [SageTVDevicesLoaded-26] ERROR SageTVDevicesLoaded - OpenDCT is restarting because it was unable to load all 6 required capture devices within 90000 milliseconds.
17:40:51.501 [SageTVDevicesLoaded-26] FATAL ExitCode - OpenDCT experienced a fatal error: SageTVManager did not load all of the expected capture devices within the allowed time.
Old 08-28-2016, 07:43 PM
It looks like they are not responding to /sys/hwmodel. I personally would try upgrading the firmware.
Old 08-29-2016, 08:56 AM
I upgraded the firmware to the latest release.
I also discovered that the Norton Security Suite would not start, so I removed it.
SageTV was then able to find the new tuners. I ran a test of 6 recording simultaneously.
Works great!!!
Thanks for all of the help and support!
John
Old 04-02-2017, 02:20 PM
LJSSageUser LJSSageUser is offline
HDHomerun 3 Tuner Problem
Originally Posted by NetworkGuy View Post
Here is what I did:
Installed OpenDCT
Started SageTV
--SNIP--
Same problem I'm running Windows 7 and using SageTV 7 trying to prepare for 9. The hdhr firmware has been upgraded on works standalone, but after that upgrade and java runtime upgrade, when I run the sagedct service with opendct disabled, the tuners are shown as not functioning. When I disable sagedct and start opendct, the log seems to find the tuners fine, but not in SageTV. My opendct log is attached. Any help would be appreciated.
Old 04-02-2017, 06:37 PM
I don't see SageTV performing a discovery in the logs. If you made the change to allow v7 to discover network encoders, all you should need to do is restart the SageTV service and see if it pulls them in now.
Old 04-02-2017, 07:00 PM
I'm not sure I understand what you mean by "discover network encoders". If you mean network_encoder_discovery=true, I have done that. I have a single computer/client and until now, haven't used the service. The hdhr is connected via the network adapter to a local 169.254 ip address, not a router.
Old 04-02-2017, 08:08 PM
That's correct about the network_encoder_discovery property. OpenDCT definitely sees the HDHomeRun. SageTV did not discover OpenDCT on startup. If you're not using the SageTV service, then all you should need to do is close the SageTV client and then re-open it. Also after closing the SageTV client, double-check that network_encoder_discovery is still true.
Old 04-02-2017, 08:27 PM
With or without the service, the client doesn't see the dct tuners. I checked while the client was loaded, and network_encoder_discovery was still true. Can I convert the sagedct mmc entries to opendct somehow?
Old 04-02-2017, 08:46 PM
BTW, I'm using Phoenix, if that's relevent.
Old 04-05-2017, 09:50 AM
[BUMP] Any ideas as to why the client isn't seeing openDCT? Anything I can try?
Old 04-05-2017, 05:17 PM
The only setting that would prevent SageTV from trying to discover OpenDCT is set correctly, so why SageTV isn't finding OpenDCT is a bit of a mystery. The only thought I have left is a potential defect in how SageTV does its discovery. It uses 255.255.255.255 which doesn't guarantee that it will hit any network interface other than the primary one. If you have more than one network adapter, try disabling all but one.
Old 04-05-2017, 05:57 PM
Is this setup not connected to the internet in any way? the 169.254.x.x address implies that there is no DHCP server on the network, so windows is just making up an IP address. It's likely this is causing your issue, as well as quite a few others quite possibly.
Old 04-05-2017, 06:14 PM
Thanks for the idea, but the problem is now moot. I started fresh with SageTV9, and it found the tuners without a hitch. Everything is working fine now, and SageTV7 is gone.
Old 05-31-2017, 09:42 PM
gcrow gcrow is offline
Opendct won't run in console
I just installed opendct and ran it in console mode per instructions. I forgot one step so didn't get a successful conclusion. I uninstalled opendct and all remaining stuff related to it and then reinstalled. Now I can't get it to run in console. A window comes up and several lines of code zip by and then it asks me to press any key and closes the console.
Any ideas?
I'm running it under the latest windows 10.
Old 06-01-2017, 04:29 AM
Don't worry about console mode. Just start the service, then start SageTV.
SageTV not finding HDHomeRun tuners Chriscic Hardware Support 4 11-06-2017 10:54 PM
HDHomeRun Prime + OpenDCT...so close! c4674593 SageTV v9 Customizations 8 04-01-2017 12:50 PM
OpenDCT: Can I use it? SDeGonge Hardware Support 7 02-20-2016 10:27 AM
WinTV HVR-1600 2 Tunners? joe123 Hardware Support 16 03-06-2007 03:25 PM
Picture Quality with Different Win-TV Tunners? joe123 Hardware Support 3 01-30-2006 06:30 PM
