Old 05-24-2017, 03:35 PM
Switching to Scedules Direct
Hi,
I upgraded to V9 about 3 weeks ago on my test system and production server. But, I only switched the test system to Schedules Direct.
I noticed today that the test system had not scheduled any new recordings. It turns out it was because of how I did the switch to SD. Instead of removing all of the tuners and re-adding them, I simply went into a tuner and changed the EPG channel lineup to use SD. That casued the problem.
When I removed all of the tuners and re-added them with SD, it started scheduling new shows immediately.
I wanted to document this in case someone else tried just changing the EPG lineup.
Tuner: (2) HDHomeRun Prime
Client: (2) HD300
Client: Mini-Client, ShieldTV
Client: Mini-Client, Fire TV Stick 4K
Old 05-24-2017, 09:21 PM
w4rh4wk's Avatar
w4rh4wk w4rh4wk is offline
interesting, i didnt delete the tuners either....I just changed the EPG channel lineup to use Schedules Direct.... I'll report back if the same thing happens to me.
Sage Server: Intel Xeon E5-2660v2; Asus Rampage IV Gene; Win 10 64bit; Nvidia GTX 1060; 16GB; 2 HVR-1250 (OTA HD)
Sage Client 1: i3-2120 3.3Ghz; AMD Radeon HD 7470; win 10; Sage Client 2:Intel Core 2 Duo 3Ghz; Intel GMA 4500; win 7; Sage Client 3: i3-2120 3.3Ghz; AMD Radeon 7000 series; Win 10
Old 05-24-2017, 09:32 PM
EnterNoEscape's Avatar
Originally Posted by NetworkGuy View Post
Hi,
I might have a little insight into what actually happened here. Schedules Direct likely replaced all of your airings with copies from Schedules Direct. Those all ended up replacing similar airings from the old guide data. SageTV was still scheduling using the old airings which didn't exist and as a result recorded nothing. SageTV is smart enough to recognize when an airing is replaced with a newer version of the same airing and it should have swapped them but for some reason that didn't happen.
Your approach should have worked fine without the added step of removing and re-adding the tuners. You don't mention it, so I'm wondering if you tried restarting SageTV before you re-added the tuners. Restarting and still having the scheduling problem would have made my assumption incorrect.
Old 05-24-2017, 09:46 PM
w4rh4wk's Avatar
I'll let you know if restarting Sage works for me if i have the same issue
Old 05-25-2017, 04:32 AM
I did not restart SageTV before re-adding the tuners. I just removed them all and then started adding them. As soon as I added the first one, I saw scheduling conflicts because there were not enough tuners. As I added the addition tuners, the conflicts disappeared.
Client: (2) HD300
Old 05-25-2017, 04:58 AM
That's very interesting. That feels like an issue somewhere between Carny and the Scheduler.
Old 05-25-2017, 05:03 AM
I have Intelligent Recordings turned off in V9.
limited_carny_init=true
Think that has anything to do with it?
Client: (2) HD300
Old 05-25-2017, 06:22 AM
That only skips intelligent recordings at startup. They do eventually become available, just a lot more slowly. That should have nothing to do with the issue you're describing.
Old 05-25-2017, 08:31 AM
That's what I did a few weeks ago and everything seems fine. Transition was pretty seamless.
Old 05-25-2017, 09:15 AM
panteragstk's Avatar
I'll be doing the same soon. Updating the guide source without removing tuners that is.
Old 06-22-2017, 03:00 PM
gcrow gcrow is offline
Schedules Direct not loading guide properly
I switched to Schedules Direct a couple of weeks ago and everything was working fine for about a week. Then it stopped downloading any of my HD programs. I renamed all the channels with SD names and the programs loaded. I cannot, however, get the TCM schedule to load - either the SD or HD version. A couple of other channels are the same way, but I only care about TCM.
My configuration is Win 10, OpenDCT, SageTV 9. Any ideas?
Thanks.
airing filter / switching from XMLTV to Schedules Direct wubdich SageTV EPG Service 2 04-17-2017 10:45 PM
Direct TV Direct Control deipert Hardware Support 2 03-01-2010 04:19 PM
Switching recordings from direct to UNC paths Brent SageTV Software 3 04-25-2008 03:17 PM
Why did I buy PVR-150? On Direct TV =/ HELP ME! McKenzie Hardware Support 11 09-02-2005 09:52 AM
Direct TV BonBon Hardware Support 8 01-16-2005 08:22 PM
