Old 08-09-2017, 08:39 AM
PeteCress's Avatar
SageTVTranscoder: How to make it run using a .BAT file?
I have been using a process management utility called Process Lasso to monitor/prioritize my PC's executables.
Recently, after fooling around with SageTVTranscoder's CPU Priority, it seems to have become invisible to the utility.
I tried a .BAT file like this:
D:\SageTV\SageTV\SageTVTranscoder.exe -y -priority idle
But no joy...
Is there a way to force SageTVTranscoder to run just so I can confirm that there is something wrong with the process monitor utility and it's not something else?
I have been unable to get PlaceShifter or Client running on my laptop or I would go that route.
Server: SageTV 7, Windows 7, Intel i7 @3.5GHz, 8 GB RAM, 80-gig SSD drive
Clients: HD200*4 over Cat5e Ethernet + Asus Zen running Client over WiFi-ac + 1 HD200 remote at another residence
Storage: NetGear Ultra-6 NAS 10 TB total w/dual redundancy. Plus (3) 2-tb local drives for RecordedTV.
Program Source: OTA antenna
Old 08-09-2017, 09:07 AM
graywolf's Avatar
graywolf graywolf is offline
It is the Windows ffmpeg so I think a scan video library should kick it off. You might need to copy some videos to a test sub folder so sagetv sees new videos
Old 08-15-2017, 04:19 AM
Any conversion job in sage will use SageTVTranscoder.
That said, what are you trying to accomplish? SageTVTranscoder is already run at idle priority when used for sage conversion jobs (and I believe belownormal priority when used for live streaming to remote placeshifters).
I believe there are properties in sage.properties to adjust these priorities. You shouldn't need an external utility to force this.
xcode_process_priority_offline=idle
xcode_process_priority_streaming=belownormal
Old 08-15-2017, 12:34 PM
PeteCress's Avatar
I have a remote user who experiences intermittantant episodes of:
  • Jerky/very slow video
  • Remote control button reverting do default value for Fast-Forward. ... I have that button programmed to do 10-second jumps. ...During problem episodes, it reverts to just fast-forwarding.
It *Seemed* like I was curing this by forcing both SageTVService and Transcoder's priorities to "High".... but last night, we had another episode and when I checked both priorities were "High", so I guess we have Correlation <> Causation.
Here's what I have in my props file:
xcode_process_num_threads=0
xcode_reduce_process_priority=true
What changes would you make to give transcoding a boost?
I guess belownormal is the obvious candidate, but what about the other three?
And, if belownormal, what alternate value?
Maybe we're finally on to something here..... -)
Old 08-15-2017, 04:31 PM
honestly, I wouldn't change it. At least on my system, 'normal' priority processes ARE more important than streaming for emote viewing. I don't want someone streaming a recording from disrupting a recording being made.
That said, I also don't use placeshifter, and instead use Plex if I'm going to watch something remotely, because the transcoder is many magnitudes better.
Old 08-21-2017, 07:19 AM
PeteCress's Avatar
...instead use Plex if I'm going to watch something remotely, because the transcoder is many magnitudes better.
I have been fooling around with Plex since reading your post.
Have you found a way to make Plex recognize Sage's TV recordings as what they are (RecordedTV)? .... Maybe some kind of Plug-In or Add-On?
Only success I have had is pointing a Plex "Other Videos" library at them, but then the user only sees Sage's under-the-hood file names instead of the show titles.
I am coming away from what reading I have done with the impression that some people have moved from Sage to Plex altogether - although I cannot imagine a better UI that what Sage puts up, maybe some find the device independence a significant feature.
Old 08-21-2017, 08:05 AM
With this:
https://github.com/ai7/sagetv-for-plexmediacenter
Some may have, but those users are likely to have come at sage FROM something like XBMC or similar, and never quite 'got' the benefits of sagetv itself, other than a thing that records tv shows for them.
Is there a way to make all of your extenders share the same properties file? wayner SageTV Media Extender 7 12-26-2010 05:07 PM
What does SageTVtranscoder.exe do? autoboy SageTV Software 5 04-23-2008 01:55 PM
SageTVTranscoder.exe jgsouthard SageTV Beta Test Software 40 11-03-2007 01:13 PM
How to make the library file music by artist and album PhillJones SageTV Software 10 04-11-2006 07:20 PM
How to make my own STV file ? lapinblanc SageTV Customizations 7 08-20-2004 02:39 PM
