Old 08-13-2017, 07:18 PM
jchiso jchiso is offline
Changed Search Behavior?
I'm posting this in the EPG subforum, since I think it may be the source of the problem, but I'm struggling with the way the Schedule Recordings search works with the Schedules Direct guide. It used to be that searches were based on literal strings that could appear anywhere in a search field.
For instance, to search for "Beachfront Bargain Hunt" you could enter the string "hfro" as a Title search, and it would return a rather short list of show titles. Now it appears that the search logic only returns matches where the searched term is at the start of a word in the field. In the above example "beac" and"barg" work, but "achfron" does not.
Given that this was not previously the case in v7 I'm wondering if there's some setting in .properties that has changed.
Old 08-14-2017, 05:42 AM
EnterNoEscape's Avatar
I can't reproduce the issue you're describing. I'm in Search TV By title and I tried hfro and one of the search results was Beachfront Bargain Hunt.
Old 08-14-2017, 07:26 AM
This is on v9, right? I would make sure that the upgrade installation is complete/repaired.
Andy
Old 08-14-2017, 02:49 PM
This is on v9. It's the same behavior with two different servers. I am using STV3, if that matters ...
Old 08-15-2017, 09:27 PM
Here's what I'm getting ...
File Type: png Screenshot from 2017-08-15 23-22-24.png (201.9 KB, 78 views)
File Type: png Screenshot from 2017-08-15 23-24-02.png (216.3 KB, 74 views)
Forum Search method has been changed Opus4 General Discussion 6 06-02-2015 07:28 PM
Scrolling through recordings... behavior changed? itsanogo SageTV Software 2 11-24-2010 12:57 PM
Can SageMC use default search behavior babgvant SageMC Custom Interface 0 12-19-2008 09:43 PM
servername for MVP bootp behavior changed in 4.1.12 JodyG SageTV Beta Test Software 2 04-06-2006 10:22 PM
Recording Library behavior Changed? TunaBoo General Discussion 6 07-15-2004 06:02 PM
