Old 12-12-2017, 06:44 PM
michaelh michaelh is offline
Search function is broken if you aren't a user
I mentioned to some friends that sage was alive again and one of them discovered that the search here is fubar'd if you aren't logged in.
As soon as you hit enter, the forum software says
"You answered the NoSpam! question incorrectly. Please reevaluate your answer or, if you found yourself unable to answer it, you can refresh for another question if the administrator has enabled multiple questions. If you find yourself repeatedly unable to answer the NoSpam! questions, please contact the forum administration."
It never gave an opportunity to answer a "NoSpam" question.
Old 12-13-2017, 08:32 AM
I logged out to look and saw it right below the Search by Keyword box.
Many people suggest using Google search with the site:forums.sagetv.com option for better results anyway.
Andy
Old 12-13-2017, 09:17 AM
Andy
you don't see that option if you're using the basic dropdown search. Only if you go to the advanced search page.
Perhaps the forum admin should disable the feature in the forum software so people will try google instead.
I think I'll put volunteering to help with some forum updates on my post-retirement list. Coming up soon.
Old 12-13-2017, 11:26 AM
Maybe I'll just disable it for searches... it was really meant to hinder user registrations by spammers.
Search function not working jerryb33 SageTV Software 2 11-30-2017 10:52 AM
Search function on this site? timg11 General Discussion 2 04-28-2015 08:41 AM
BMT 4.8 / Phoenix 2.2.1 - After upgrade, Browse function broken mkanet Batch Metadata Tools 10 12-06-2010 07:04 AM
Search Function Question (only getting numbers in search) SDeGonge SageTV v7 Customizations 2 10-01-2010 10:32 PM
Web User Interface + Secure = Broken Streaming Function jmoney579 SageTV Customizations 1 05-28-2008 01:51 AM
