Program Guide won't show both EXTEND and Prime channels when identical channel ids
I have a 2 tuner Homerun EXTEND and a 3 tuner Prime. Some of the channels have the same channel ID for both the Prime and Extend, e.g., 2-1 and 782. However, only the 2-1 channel shows in the program guide, not both 2-1 and 782. Sometimes i may want to record the channel on the Prime instead of the Extend but i can't.
Is it possible that sage could record on 782 if 2-1 is busy at the time even though 782 does not show in the program guide?
- James M - Server: Asus P5B Deluxe, 8GB, Core2 E6600 @2.4GHz, Windows 10 X64 Pro Storage Internal: (1) 250GB, (2) 2TB, (1) 4TB Storage External: Sans Digital 4-Bay eSATA Port Multiplier RAID Enclosure with (4) 4TB Drives Capture Devices: HDHomerunXTEND, HDHomerunPrime Clients: (1) STX-HD100 HD Media Extender, (3) HD200 HD Theatre, (1) HD300 Last edited by brandypuff; 02-08-2019 at 12:47 PM. |
"Note: If you have configured multiple sources using different Programming Guide Data providers in the Source Setup, you may see multiple entries with the same channel number, representing the fact that those multiple sources use the same channel number for different networks. Alternatively, if the same network is available on both sources, but on different channel numbers, that network may be listed only once using only one of those channel numbers. For example: CNN may be on both sources: as channel 6 on one and channel 25 on the other. In this case, CNN will be displayed as channel 6 or 25, but not both; however, CNN will actually still be available from both sources on the proper channels. SageTV will internally track which channel belongs to each source. If all sources use the same channel lineup, all channels are listed only once." Don't confuse "channel number" (2-1 or 782) with Sage's 5-digit "Station ID". You can see the Station ID in Setup -> Video Sources -> (source) -> Channel Setup. The Station ID value comes from your EPG provider.
System #1: Win7-64, Core2-Quad Q9400, 8 GB Mem, 4TB HD. Java-64 1.8.0_141. Sage-64 v9.2.1 ATSC: 2x HDHR-US (1st gen white) tuners. HD-200. System #2: Win7-64, I7-920, 8 GB Mem, 2TB HD. Java 1.8.0_131. Sage v9.1.6.747. ClearQAM: 2x HDHR3-US tuners. HD-200. System #3: Win7-64, I7-920, 12 GB Mem, 4TB HD. Java-64 1.8.0_141. Sage-64 v9.2.1 ATSC: 2x HVR2250; Spectrum Cable via HDPVR & USB-UIRT. 3x HD-200. |
Yes, i have identical station id's on two different lineups for a few channels.
So let me get this straight. If i have the Extend with two tuners and the Prime with 3 tuners, and chan 2-1( extend) and chan 782 (Prime) have identical lineups but only 2-1 shows in the guide, then Sage could be recording a show on 782 even though i scheduled it using guide data for 2-1? This is confusing because i tell my wife she can record two simultaneous shows on the Extend and 3 on the Prime. I won't know if Sage is using the Prime rather than the Extend to record a show that has identical lineups on both devices so i could in fact schedule more than two shows using the lineup for the Extend but won't know which channels overlap with the Prime. ugh. confusing.
- James M - Server: Asus P5B Deluxe, 8GB, Core2 E6600 @2.4GHz, Windows 10 X64 Pro Storage Internal: (1) 250GB, (2) 2TB, (1) 4TB Storage External: Sans Digital 4-Bay eSATA Port Multiplier RAID Enclosure with (4) 4TB Drives Capture Devices: HDHomerunXTEND, HDHomerunPrime Clients: (1) STX-HD100 HD Media Extender, (3) HD200 HD Theatre, (1) HD300 |
In most cases it doesn’t really matter which tuner Sage picks - all that’s important is that your show get recorded. If you really prefer one tuner over another, you can set the merit higher for the preferred device.
Server: Athlon II X4 630 CPU, Gigabyte MA770T-UD3P (AM3) Motherboard, VisionTek Radeon HD4670 PCIe w/ Component output to 50" CRT Rear-Projection HDTV (Mitsubishi), Win7-64Bit (Home Premium), 4GB RAM Capture Devices (8 tuners): Colossus (x1), HD-PVR (x1), HDHR Prime (x2),USBUIRT (multi-zone) Source: Comcast Cable Primary Client: Server Other Clients: (1) HD200, (1) HD300 Retired Equipment: MediaMVP, PVR150 (x2), PVR150MCE, HDHR, HVR-2250 |
Using Favorites, it's possible to record 5 programs at the same time. You won't know which tuner Sage is using to do the recording. That's part of the beauty of setting up Favorites (and almost NEVER setup a manual recording). Since most cable-tv stations air any given program multiple times, Sage is able to look ahead to survey all airing times and juggle it's use of tuners and recording times to get the programs of interest. Of course, that might mean that Sage may not always record the very first airing of every one of your Favorites, but it (almost always) will record what you want. And if it can't, you'll be notified that there's a conflict, allowing you the opportunity to prioritize which of the conflicting programs is the one of higher importance to you. On the other hand, if your wife is selecting programs from the Guide and then setting them up as a Manual record, then Sage isn't going to help or over-ride that. Try it.
System #1: Win7-64, Core2-Quad Q9400, 8 GB Mem, 4TB HD. Java-64 1.8.0_141. Sage-64 v9.2.1 ATSC: 2x HDHR-US (1st gen white) tuners. HD-200. System #2: Win7-64, I7-920, 8 GB Mem, 2TB HD. Java 1.8.0_131. Sage v9.1.6.747. ClearQAM: 2x HDHR3-US tuners. HD-200. System #3: Win7-64, I7-920, 12 GB Mem, 4TB HD. Java-64 1.8.0_141. Sage-64 v9.2.1 ATSC: 2x HVR2250; Spectrum Cable via HDPVR & USB-UIRT. 3x HD-200. Last edited by JustFred; 02-08-2019 at 10:16 PM. |
Program guide customization: channel/show information | domat00 | SageTV Software | 2 | 08-20-2017 09:56 AM |
Show Channel name instead of Call Sign in Program Guide | lenkost | SageTV Software | 5 | 12-25-2010 08:36 PM |
Embarrassingly simple question, How to channel program guide colors on Show type | jptheripper | SageTV Beta Test Software | 5 | 10-30-2010 01:46 PM |
Two identical tuners and one program guide. | avogodro | SageTV Software | 16 | 05-26-2010 08:20 PM |
All sub-channels show the same program contrary to guide data | rooobosmith | SageTV Software | 13 | 07-15-2009 08:52 AM |
