New bug, size 15 font clipped in many menus
I just upgraded to 9.2.1x86 from 9.1.9 and I've noticed that in many screens the top of the text is clipped.
Attached is a sample. In the schedule view, the font is set to 15. Any other font size seems to scale just fine (even bigger fonts). The same result can be seen in some other on screen menus as well.
Server: SageTV 9.2.1x86 on Windows 7 x64 Home Premium, Core 2 Quad Q6600, 4gb RAM, OpenDCT, Java 1.7u80 Display: EVGA 1030 GT to Sony LED TV via DVI-HDMI Capture Devices: HDHR Prime for Comcast, HDHR Dual for OTA Clients: Nvidia Shield Android miniclient, 2 PCs Retired: ATI HDTV Wonder for OTA HD, VBox DTA-150 for OTA HD, Conexant 2388x (Blackbird) analog capture to Comcast DTA cable box with USBUirt, ATI Remote Wonder Plus, Fanless Radeon HD 6450 |
FreetypeFontJNI.dll is now being compiled from source code for both 32 and 64-bit versions. Earlier V9 versions used the V7 DLL. Something must be different there. Can you try shutting down SageTV then backing up and replacing that DLL with one from an earlier version to see if that helps?
You can also try setting “ui/disable_freetype_fonts=true” in sage.properties. Last edited by wnjj; 03-27-2019 at 12:05 AM. |
Thanks for the rapid troubleshooting options!
I replaced FreetypeFontJNI.dll with the older one from 9.1.9 on the server install. YES! Success.
That’s going to be a tough one to sort out. The source code for Freetype fonts is part of the native Linux environment (which is included in MinGW for the Windows build). In other words we have little to no control over it. There may be ways to adjust the SageTV graphics system to accommodate. I found some old revision notes from early version 7 that talked about clipped or offset glyphs.
Ultimately, I just did a fresh install to get rid of the issue. There must be something unique about the upgrade that causes the font issue where a clean install is not affected by it. Probably not helpful, but just letting you know that I was also affected by this and that it was tied to an upgrade. |
Waylo, if you wanted to try restoring the “new” DLL and rename the fontcache directory to see what happens that would prove it. Otherwise I’ll try to replicate it here. |
Great troubleshooting, I'll try it when I get home.
Okay, I replaced the 9.2.1. dll to its original state, erased fontcache and restarted SageTV. Great, it worked!
I did the same on my windows client install with good results too. BUT! On my Android client, all text became horribly garbled. I don't know why that would be. (I also realized that the fix on the server did not fix the clipped text on the Android client). Since I rely on the Android client quite a bit, I changed it back on the server to the old fix (rather have it clipped that garbled).
Sorry I wasn't so clear. An attempt to clarify:
1. Changing back the old .dll, OR removing the fontcache folder and keeping the new .dll, fixes the characters on the machine the change is made. So both my x32 server and x32 client can be fixed with either method. 2. I also use the Android miniclient on my Nvidia Shield. I'm not sure how the fonts work in this implementation. I will probably need to do more experimentation here to confirm these observations, but here are the scenarios so far: a. When the server was first upgraded, the type was clipped on the server, and also on the miniclient b. When the server was fixed with the old .dll, the type was fixed on the server, but still clipped on the miniclient. c. When the server was fixed by clearing the fontcache folder (keeping the new .dll), the miniclient had horribly garbled text. I had to restore the old .dll to the server to get readable text on the Android miniclient. If you've ever followed the android miniclient threads, similar garbled text occurs when memory is an issue with the shield. Seems like the app really doesn't like being kept open in the background. I do not know if this is a related bug or not.
Server: SageTV 9.2.1x86 on Windows 7 x64 Home Premium, Core 2 Quad Q6600, 4gb RAM, OpenDCT, Java 1.7u80 Display: EVGA 1030 GT to Sony LED TV via DVI-HDMI Capture Devices: HDHR Prime for Comcast, HDHR Dual for OTA Clients: Nvidia Shield Android miniclient, 2 PCs Retired: ATI HDTV Wonder for OTA HD, VBox DTA-150 for OTA HD, Conexant 2388x (Blackbird) analog capture to Comcast DTA cable box with USBUirt, ATI Remote Wonder Plus, Fanless Radeon HD 6450 Last edited by waylo; 03-29-2019 at 09:26 AM. |
Font Size | chadman | SageMC Custom Interface | 6 | 07-12-2009 06:36 PM |
Font Size | TripleTapper | SageTV Media Extender | 4 | 12-12-2006 03:19 PM |
Changing font size | Whiskeyjack | SageTV Software | 2 | 11-29-2004 08:39 AM |
Font size for EPG | srothwell | SageTV Software | 4 | 08-04-2004 01:00 PM |
Change font size in EPG? | andrewswright | SageTV Software | 1 | 09-22-2003 07:37 AM |
