Old 05-24-2019, 07:26 AM
still have corrupted EPG guide data
Is there a way to force sagetv to re-download all sdepg data from scratch? I would like it to be able to override wrong programming listed due to corruption within sagetv. I have found that if i have a corrupted video file imported into sagetv that it will corrupt the show listings. ie I had a corrupted few episodes of Everybody Loves Raymond. in various places within guide it would display that episode as an upcoming airing instead of the correct show in multiple time slots. This has happened with lots of different shows so that epg negatively affects recording schedules, by taping the wrong show or populating the database with non existence episodes instead of the genuine ones. I will see shows listed that I know are hour long shows popping up in guide as 30 minute shows. I have found that unselecting a channel & reactivating it doesn't repopulate the epg only fills in missing show listing if present, but doesn't have any impact on wrong listings. I have found that the only time that a change of listing happens is if SD sends an update for programming change with an alert attached. Can we improve upon the epg? I know the extra scanning isn't probably welcome, since it puts a bigger workload on the servers. A manual option to fix epg when there is an issue would be nice though, esp when it is a problem originating from the user end rather than SD.
Old 05-24-2019, 08:07 AM
wnjj wnjj is offline
Does deleting sdmd5sched then triggering another EPG update clean things up?
Old 05-24-2019, 06:57 PM
jpwegas jpwegas is offline
Just curious, are the video files from an OTA source? I wonder if the corrupted file has corrupted ATSC EPG data.
Perhaps you could try disabling the OTA EPG scan/import? See https://forums.sagetv.com/forums/showthread.php?t=24713
--John
Request for pointer to alternate guide data plugin when Sage stops providing EPG data Savage1701 SageTV Customizations 3 04-29-2012 05:50 AM
Unable to get Guide data for OTA channel that has data at Zap2it wayner SageTV EPG Service 15 07-09-2010 06:23 AM
Corrupted Wiz.bin = No Guide Updates, solved skyeclad SageTV Software 1 03-30-2010 10:20 AM
Corrupted video files? Missing data - randomly CHANGING missing data? BlueRidgeMark SageTV Software 31 04-02-2007 04:24 AM
Channel Guide corrupted - same show every hour, every day, every channel CanadianEh SageTV Canada 2 10-20-2004 11:11 AM
