Old 09-05-2009, 12:57 PM
Microbus613 Microbus613 is offline
Sage TV Freeze with Windows7 - PVR-150
I was able to install my PVR on my computer, was removed from an old P4 computer, now into a Double-Quad 2.4Ghz with 8gb of memory.
My understanding was that it should have work much better than on a P4.
I am using the hauppage driver found on CD V 4.6 and using SageTV v 6.6.2
Not installed any of my clients has I cannot make this works.
Playback seems fine, but the tuner frezze up sometimes (most of the times), eventually I get a fine tune for a while. Also noticed that my mouse will also freeze for a second of 2 while Sage TV is working as a Tuner.
I would appreciate any help.
Thanks.
Old 09-05-2009, 01:26 PM
PVR 150's Do Not work very well with 4 gig of memory and up. It is documented all over this forum.
http://forums.sagetv.com/forums/show...904#post377904
Old 09-05-2009, 01:37 PM
So I should get another PVR?
Which one should be ok?
Old 09-05-2009, 04:04 PM
So I got a new HVR 1600.
Now everything works fine.
I'll put the 150 in an older computer.
Solution: Sage / HD-PVR lock up/freeze when I turn the TV on / change source. bastian74 Hardware Support 0 01-30-2009 06:41 PM
PVR-150 Issues (Don't think it's sage). FidgetyRat Hardware Support 7 12-20-2006 08:30 AM
Instability with Sage 5.0.4, PVR-150, XP dkk SageTV Software 0 10-28-2006 11:56 AM
PVR-150 remote and Sage TV xjas Hardware Support 4 09-15-2005 05:18 PM
Sage 2.1 Freeze with second PVR card connected extreme.paradox SageTV Software 7 01-10-2005 11:08 AM
