Old 01-20-2009, 06:22 PM
rerooks rerooks is offline
SageTV and Java
I am running SageTV, and it is the latest beta version, but I don't think it has much to do with Sage directly. What happens is that after a couple of days of Sage running, I cannot fast forward anymore, the video will just lock up, and I have to hit stop, and then play again. I have enabled debug logging, and here is what I see:
Tue 1/20 19:12:06.465 I/O error reading in push thread:java.io.IOException: Insufficient system resources exist to complete the requested service
Has anyone encountered this before? Any suggestions?
Ray
Old 01-20-2009, 06:27 PM
What version of java? Running any plugins? Remove any other versions of java except for the latest. (Ver 6 build 11) Remove any plugins and just run SageTV naked. (The program, not you.)
Old 01-20-2009, 06:35 PM
I had build 7 and 11 installed. I just un-installed build 7. I didn't know I had two versions. As far as plugins, do you mean stvis? Otherwise, no. This machine doesn't do much more than Sage and being a fileserver.
I will see how it goes. Thanks.
Ray
Old 01-22-2009, 09:50 AM
Still more problems
Last night I got a lot of errors of 333 Event Ids inside the Windows Event Viewer.
"An I/O operation initiated by the Registry failed unrecoverably. The Registry could not read in, or write out, or flush, one of the files that contain the system's image of the Registry."
I am starting to wonder if I should just re-install WHS.
Ray
java
Testing Sagetv with Java Access bridge nallan SageTV Software 0 04-01-2006 07:31 PM
Successful SageTV Install on Via Epia System with Hauppauge 350 gazer Hardware Support 0 03-23-2006 01:48 PM
Start SageTV with java debugger enabled ? dflachbart SageTV Studio 5 03-05-2006 02:31 PM
Good/Bad Versions of Sun JAVA Related to SageTV AWS General Discussion 6 11-10-2005 02:17 PM
