Old 08-12-2009, 12:12 AM
shatter shatter is offline
SageTV Client Having Trouble Playing back Live TV
Hi,
I am running SageTV Client on a XP SP3 machine on an all gigabit network. The client will play back recorded shows fine but refuses to play Live TV. If I try to watch a show, I will get the overlay on a black screen for about 5-10 seconds and then it usually will go back to the program guide with the red "REC" button showing the program is being recorded. When I then go back to trying to watch the show the playback starts immediately but the video/audio will eventually hang.
The server doesn't have any problems in playing live tv to the television it is hooked up to.
I have made sure my server and client are both running Java 6r15 and I am running SageTV v. 6.6.2.218 on both the server and client. The server is running XP SP2.
I have tried changing network settings (jumbo frames on and off), updating network card drivers, running older ones without any change in behavior.
I am including debug files for the server and client. Interestingly enough, on the debug try it started playing immediately on the client but then when I tried to stop the live tv view and pick another channel, it went right back to the old behavior described above.
I have defrag'd all the drives on the server and made sure there is plenty of free space on the drives of the server and client machine.
All help is appreciated, thanks!
Chad
File Type: txt tv.sage.mod.0.log.txt (305 Bytes, 143 views)
Hardware: Intel i5-2500, ASUS P8H67-M EVO, 12GB DDR3 RAM, Hauppauge HD-PVR, Intel PCIe NIC, BD-ROM drive, wireless keyboard/mouse combo, HD-200, HD-300
Software: Win 10 Pro 64-bit, SageTV 9.0.9.441
Problem Playing back "live" video from R5000, Dish recordings Ralphjb SageTV Beta Test Software 1 01-07-2009 07:50 PM
Live TV playing back wrong tuner... Slipshod SageTV Software 0 04-18-2008 02:21 AM
Webscheduler recordings - playing back in SageTV ero SageTV Software 2 03-27-2008 07:23 AM
Playing back PAL DVDs via SageTV - is it even possible? fbures Hardware Support 4 04-29-2007 08:33 PM
SageTV crashes sometimes when it finishes playing back a file turak SageTV Beta Test Software 1 05-13-2004 03:26 PM
