Old 10-06-2021, 08:42 AM
tvmaster2's Avatar
Windows 10, sleeping, auto-wake up etc…
Have just upgraded to Windows 10, and am wondering if anyone has set up an auto-wake up system for their Sage server.
With W7, I just set the box to be on, 24/7.
Has anyone set up a remote wake function for either recordings, or extender use, in Windows 10?
Old 10-06-2021, 10:50 AM
trk2 trk2 is offline
Yes, I have done this for my server and there were some Win 10 "features" that I had to disable to get everything working properly. First, I had to disable "fast startup" and "hybrid sleep". Then I also had to configure Win 10 to use the S3 sleep state. I don't remember how to do these actions, it was a bunch of googling and following tutorials, but those were the big steps that needed to be performed.
Old 10-07-2021, 09:09 AM
tvmaster2's Avatar
ok, thanks - that's a start
Old 10-08-2021, 06:48 AM
I tried sleep and it worked, but I went back to running 24/7.
ASRock B450M Pro4 AM4 MB, Ryzen 5 2600 3.4ghz, Crucial Ballistix Gaming 32GB (2 x 16GB) DDR4-3200, EVGA GT 1030SC, WD Black NVMe SSD 250GB, 1x WD120EFAX 12TB, 1x WD80EFAX 8TB, 1x WDBH2D0040HNC 4TB, USB-UIRT, Colossus 2, WinTV-DualHD USB, Windows 11 64bit
V9.0.9 and Windows Not Sleeping with Service RBraverman SageTV v9 Customizations 6 12-01-2016 02:17 PM
SageTV wake a sleeping computer to record? cnr1089 SageTV Mac Edition 9 03-19-2011 08:41 AM
Windows 7 wake from S3 sleep and record jimbo67 SageTV Beta Test Software 13 10-06-2010 04:37 PM
Windows 7 - will not wake with USB-UIRT timg11 Hardware Support 5 08-16-2010 11:59 AM
Haupauge remote won't wake sleeping client sometimes, and possible reason. mdmint Hardware Support 2 05-28-2004 09:26 AM
