Old 01-19-2010, 04:18 PM
Joe Bloggins Joe Bloggins is offline
Recording from STB with HDMI interface output only
Hi,
I have an IP-based STB (SA IPP430MC rebranded to Belgacom) that has only an HDMI output interface. I want to connect it to my Hauppauge HD PVR box that has only Component input. Will a HDMI to Component cable like the one listed below work?
http://cgi.ebay.co.uk/Component-Cabl...item2eaa8ee239
Martin
Old 01-19-2010, 04:32 PM
david1234 david1234 is offline
There is no cheap/easy way to convert a digital hdmi source to analog component.
That cable doesn't actually change the digital output of the hdmi to distinct analog signals that component video uses.
What this thing does is adapt a (usually DVI) video card output source, which the card is outputing an analog signal to specific pins, and splitting the individual analog signals to the correct component cable.
Sorry- this isn't stated very well, but it should make enough sense anyway.
Old 01-19-2010, 05:40 PM
jpt1303 jpt1303 is offline
You could go with an HDfury, not a very cheap solution though. You can check the converters out at www.hdfury.com
Old 01-19-2010, 07:27 PM
The HDFury2 is really your only option, the HDFury "1" only offered RGB output AFAIK.
Old 01-20-2010, 02:29 PM
will will is offline
With each new version of HDMI will you need a new HDFury? It seems like they are on version 3 which works with HDMI 1.3.
Old 01-20-2010, 03:20 PM
Not really. Not much changes WRT video in each HDMI revision, and given that the output of the HDFury is analog (VGA/Component) which doesn't support stuff like lossless audio bitstreams, 3D, ethernet, return commands etc, there's no reason you'd need a new HDFury.
component, hd-pvr, hdmi, recording, stb
480i over HDMI - HD200 output not standard? cncb SageTV Media Extender 4 07-21-2009 10:28 AM
HD200 no HDMI output webwalker SageTV Media Extender 26 02-19-2009 11:17 PM
HD Extender Output HDMI + Analog Audio? jasoninva SageTV Media Extender 3 08-18-2008 03:14 PM
Output 1080p 120hz via HDMI? Grasshopper SageTV Media Extender 1 06-21-2008 10:16 AM
