Old 01-06-2016, 12:11 PM
rickybee rickybee is offline
IR not pressing enter after channel change
I just moved and Comcast in their infinite wisdom gave me a new STB which I cannot get working with my Hauppauge IR blaster. Anyway, I switched gears and am trying my USBUIRT to control this one. I found some software called LM Remote Keymap from Gestion which is 95% working. I am soooo close.
I have 'learned' and from the LM Keymap software all keys 0-9, direction and select are working. I can enter a channel number and the STB changes just fine. The part I'm stuck on is when SageTV changes the channel, the numbers get transmitted fine but there's no 'enter' to confirm.
I found the option for 'Channel Change Confirm Code' in the Source Setup but the list of options is blank. If I try to learn a new command I get a message that there was an error learning the code, even before pressing anything on the remote.
Any help would be appreciated
** update ** well that was simple, I rebooted SageTV and now it is working.
remote, usb-uirt
How to enter 4 digit channel via keyboard ainakea SageTV Software 1 06-25-2009 07:12 AM
Studder after multipath, channel change, & show change TBacker SageTV Software 1 01-05-2008 09:01 AM
OK/Enter button activates previous channel? Athfar SageTV Software 2 12-06-2007 05:41 PM
channel change without enter? lcddream SageTV Software 1 12-28-2006 11:37 PM
Can I set it so I don't need to press OK/select when I enter channel #? vorius SageTV Software 5 09-05-2006 05:28 PM
