Old 09-21-2004, 10:40 AM
digitalgm digitalgm is offline
A pipe dream or possible?
All,
I have just purchased my sageTV bundle with the 250MCE card and the UIRT and am so pumped to install it. That aside, I would like to know about how sage handles resume and suspend of the computer. I ask because I went from a ReplayTV before this and it had a power button. When the power button was pressed the unit would go into standby mode and spin down the disks.
My questions are as follows :
1) Can I suspend the computer through remote that I bought (Streamzap)? If so, do I need to use Girder for this functionality or is it done through sage?
2) I have seen some programs that are written to wake up sage when recordings are scheduled to record. With these, does the computer re-suspend when the recording is done?
3) If I suspend the computer and resume it, will my UIRT and sage still work reliably?
Old 09-21-2004, 12:39 PM
Re: A pipe dream or possible?
You need girder AFIAK.
Are you talking sagewake? I think it's set to sleep the PC if no recordings are schedule for some time (not sure how long).
That's the tricky question, I played with sagewake a little, and it did indeed wake the PC. However some of my hardware never wakes up if I put my PC in S3, so I gave up.
Old 09-21-2004, 01:05 PM
Thanks for the info. As far as #3 goes, what hardware are you using? Do you use the UIRT at all?
One more question - if I suspend my computer with girder (or whatever), can I resume it by using the remote?
Thanks a million...
PS - I like your SN, I have a '65 Stang myself =)
Currently building the mother of all SageTV Installations .... XXL SageTV
Summary: 40 Analog Tuners, 10 OTA HD Tuners, 3 Sat HD Tuners, 20 Client HTPCs, Dedicated Commercial Skipping Server Wish me luck!
Old 09-21-2004, 01:18 PM
It's my M-Audio Revolution that never resumes, kind of hard to watch TV without sound
Anyway, I've got a Streamzap (no UIRT) that IIRC works after resume, but I can't resume my PC from S3 with anything but the power button on the PC.
