Old 01-31-2016, 05:12 AM
Pelicanjoe Pelicanjoe is offline
Question Windows Installation V9 Success Stories
Hi All,
I'm going to be attempting a new installation of Sagetv v9 server on a new computer running Windows 10 and using Hauppauge HVR-2250.
Iv'e noticed that there is a beta installer and there are other instructions on how to install v9 manually.
Has anyone had any great success with any method? Can you tell us how you successfully installed v9 on a new computer?
Joe
Old 01-31-2016, 08:43 AM
jusjoken jusjoken is offline
IMHO there is really no risk to using the latest installer on a clean system so it should be the best option. It should also cleanly uninstall if you are not happy with the results...but if you have issues please report back so I can work to resolve.
k
Old 01-31-2016, 10:25 AM
HelenWeathers's Avatar
Use the installer!!! Works great!
I have just done a clean install of Sage 9 on Win 10/32 with Hauppauge 2255 cards.
Best is to install and close the installer, run Sage from the desktop icon to do the initial setup wizard and then set up your service app if you will be running Sage as a service.
It went flawlessly for me with channel scan and channel preview both working perfectly. (When I tried to do my first setup run in service mode I did have a glitch in the setup wizard)
Working great for OTA record/playback with default setup settings.
Old 01-31-2016, 11:14 AM
Talking
Great information Jusjoken and Helen! I was looking at your beta installer thread, but it was reading as if you needed to install v7 first then v9 over it. And Helen, your posts were sounding like they were having some issues. Great to know the work-around!
So, just to be sure I understand what you are saying, you don't need to install v7 then v9 over it?
Also, Jusjoken, do you update the initial beta installer link when a new version comes out? I noticed that there was one at the start of the thread and one toward the end (an update). Would both of them be the same? I did not click on it to see.
Hopefully it is easier than I originally thought!
Thank you!
Joe
Old 01-31-2016, 11:59 AM
.....So, just to be sure I understand what you are saying, you don't need to install v7 then v9 over it?....Joe
Yes, just install the V9 Sage UNLESS You have a Sage license and need to keep the closed caption function on your server itself. The CC data is embedded in the stream from the 2250 tuners, so it works on extenders without needing any of the earlier Sage components.
Old 01-31-2016, 12:08 PM
The links are both the current version....The first post autoupdates and will always point to the latest windows installer....however, we did run into a little version number issue between myself and stuckless so there is a NEWER folder on BinTray called 9.0.4.220 than the one I created with 9.0.4.224.
So I will get that corrected later today but in the mean time the latest is here....
Old 01-31-2016, 02:02 PM
I have corrected this so all files are now available in the 9.0.4.220 location on BinTray.
Old 01-31-2016, 06:03 PM
Thanks for this great information! I am still building the PC, but this will be very useful and probably helpful to others.
Helen, you said...
I do have a sage license and plan to use it for EPG data. This won't hurt or help that use of the license?
Joe
Old 01-31-2016, 07:19 PM
Helen, you said...
Thanks! Joe
I only mentioned the license in the context of Closed Captioning. IF YOU NEED CC on the server you'll need to install Sage 7 first so whel you upgrade to Sage 9 the components from V7 having to do with CC extraction are kept and reregistered when you install V9 which currently has no CC support,
Old 01-31-2016, 07:21 PM
Thanks Helen!
I thought you meant that, but just wanted to be sure.
Cheers!
Joe
Old 02-01-2016, 11:17 AM
AzJazz's Avatar
AzJazz AzJazz is offline
Hi - I have v7.1.9 installed on my Win7x64 PC. I have the original HDHomeRun as my signal source. I'm primarily using the SageTV service on my PC, but occasionally watch videos on the PC as well.
Can I just run the Windows 9.0.4.220 SageTVSetup.exe, and be ready to rumble? Is there a way to go back to v7.1.9 if I want to?
AzJazz
AzJazz
SageTV: v9.x (on Win7x64)
CPU: Core i7-3770 @ 3.40+ GHz
RAM: 16GB DDR3 1600
GPU: nVidia GTX-770
RCVR: HD-Homerun
STB: STX-HD100, HD-300
Old 02-01-2016, 05:22 PM
bryanzim bryanzim is offline
I did a clean install of 9.0.3.194(Beta 1) using the new sdepg plugin and 4 networked hd home run tuners and everything works fine. I did not try to upgrade 7.1.9 and beta 3(9.0.4.220) does not work with HD Home Run network tuners which exhibit capture failures.
Old 02-01-2016, 06:49 PM
AzJazz's Avatar
Thanks, bryanzim! I'll hold off with trying v9 for now, I guess. I was trying to fix one problem, but I'll probably create a whole ton of others if I have to start from scratch with v9, especially if my HDHomeRun may not work for a while.
AzJazz
RAM: 16GB DDR3 1600
GPU: nVidia GTX-770
RCVR: HD-Homerun
Old 02-02-2016, 10:01 AM
millerbrad millerbrad is offline
I installed about a month ago using the manual upgrade from a fresh Sage7 install. Once I figured out how to install and configure the Schedules Direct EPG plugin, it has worked great.
I also have four HDHomeRun tuners, and have had no problems with them whatsoever. Just make sure you run the HDHR setup program that came with the drivers and switch your tuning program to Sage (I initially forgot to change it from MediaPortal, and it was slightly glitchy until I flipped it).
I actually didn't even know about running Sage as a service until a couple days ago. If you're setting up for the first time, make sure you do that before you configure anything (run the program in the Start menu folder for Sage and set it up to run as a service). Switching to Sage as a service caused me to lose a lot of my settings, so I've been trying to reconfigure what I had fine-tuned over the last month. Still can't get my Gemstone recordings view to look the way it did before...
Old 02-02-2016, 01:04 PM
Narflex's Avatar
Narflex Narflex is offline
Sage
If you switch from standalone to service mode and want to retain all your settings; just copy the Sage.properties file to SageClient.properties (copy, not rename) and that should do the trick.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 02-02-2016, 03:32 PM
Perfect! That is exactly what I needed. Even fixed my recordings list back to how I had it. Thanks!
Old 02-02-2016, 09:45 PM
Yesterday I uninstalled my v7 setup, (backing everything up), and SageDCT. I used the v9 and OpenDCT Windows installers to get things fully running again in about an hour and a half, (including configuring channel lineups, plugins--I don't use many and just the stock UI--etc.) Very painless. I have a license which I entered during the install, but don't need CC, so didn't install v7 first.
I was going to do a manual v9 upgrade over the holidays, but am glad I waited. People have been doing some great work developing and helping debug these tools. Tuners are an InfiniTV4 and a 2250.
Old 02-03-2016, 03:34 AM
Have you tried the latest beta 003 installer or are you running the 001 installer which came out a month ago? I have HD Home Run tuners also using the 001 installer. The 003 installer did not work for me and I experienced capture failure and was unable to perform a success full channel scan. The scan would run but no channels found.
Old 02-03-2016, 07:19 AM
Success! I fully uninstalled my version 7.19 and wiped the SageTV Directory completely. Did a full install of 7.19 and without running it installed Beta 003 on top of the clean 7.19 install. Without starting the Service, I ran the application and fully configured it including my Colossus Capture card (which had never worked with Version 9). After all this Version 9 appears to be working properly with my HD200's and HD300's. It also appears that the Java Heap is being read properly for the first time under version 9. I will test a windows Client install on another machine or two later tonight, but it does look like things are finally working well and all is good with my existing setup. Now I just need to walk through testing the new Android Client as I need additional extenders for a second install at a different house! Thanks to everyone for all you have done!
Old 02-03-2016, 07:55 AM
The day after Christmas, I did the manual install detailed here (this was before the SageTV v9 Windows installer was created).
Yesterday, I swapped out my Sage.jar file with the latest 9.0.4.220 version. My HDHR tuners are still working great. I even ran another channel scan after swapping the file --- no problems at all.
hauppauge 2250, version 9 success stories, windows 10
Windows 8 x64, HD-PVR, FIOS [SUCCESS] ShortySeanbo Hardware Support 12 02-05-2013 10:27 PM
Getting the channels back - success stories only please wigglytoes General Discussion 5 04-29-2010 07:23 AM
SageTV Server running Linux? Any success stories? Brent SageTV Linux 13 07-02-2008 08:48 PM
Anyone with wireless MVP success stories? jkf SageTV Media Extender 8 06-13-2007 07:18 PM
SageTV Client - Setup - Extender? - Success Stories? DRM2PVR Hardware Support 11 11-22-2005 06:00 PM
