Old 01-27-2022, 08:54 PM
jhkoenig's Avatar
jhkoenig jhkoenig is offline
New problem running out of 64bit Heap
I have added 2 HD300s to my mix, and now have irregular Java Heap out of memory failures. I'm running 64bit Sage on a 16GB Windows server, so I should be able to increase the heap to a massive size, but it seems to be pinned at 1GB, regardless of what I put into JVMMaxHeapSizeMB in the registry setting. Is there a way to get beyond 1GB?
Win10@16GB RAM, 30TB Disk across 6 disks. 2 Prime tuner units
Sage v9 (64bit) using OpenDCT to control the Primes
2 HD-300s, an Android mini-client, and a Windows client
Old 01-27-2022, 09:49 PM
jusjoken jusjoken is offline
Try searching the registry for JVMMaxHeapSizeMB as it will appear at least twice on 64 bit systems... Change both values.
K
Old 01-27-2022, 09:55 PM
jhkoenig's Avatar
K
On my server, JVMMaxHeapSizeMB exists only once, at ../Wow6432Node/Frey Technologies/SageTV. Right now I have it set to 3000hex (12GB).
Old 01-27-2022, 10:04 PM
For 64 bit sage it should be here...
HKEY_LOCAL_MACHINE\SOFTWARE\Frey Technologies\SageTV\JVMMaxHeapSizeMB
Old 01-27-2022, 10:05 PM
jhkoenig's Avatar
So I was REALLY bad at running search in RegEdit. I found the other entries, set them to 3000hex and will see how that works. Thanks for the advice!
Old 01-28-2022, 10:06 AM
wnjj wnjj is offline
For future reference, “Wow6432Node” in the registry path means it’s for a 32-bit application on a 64-bit system.
Windows Installer
Old 01-28-2022, 10:28 AM
12GB should be way more than you need. I am running Sage on unRAID, and I use 3GB. I once turned on every extender and a bunch of Placeshifter clients. I think I had about 12 miniclients connected simultaneously and I never used the entire 3GB. Apparently Java in Windows is less efficient so that may not be quite the same in Windows but 3 or 4GB should be plenty.
Changing JVM Heap Size on Windows 10 64bit Lucas SageTV Software 7 01-19-2019 06:35 PM
Linux 64bit MiniClient (issues with JTux on 64bit) stuckless SageTV Github Development 23 08-19-2015 12:54 PM
Java Heap running low after 12 hours redbaron73 Diamond 8 05-12-2011 03:42 PM
Problem when running in Win7 64bit rdefino SageTV Software 1 11-30-2009 12:47 PM
Anyone running 64bit with SageTV on Linux? bcjenkins SageTV Linux 74 07-05-2009 12:59 AM
