Old 01-28-2022, 12:28 PM
CptKirk CptKirk is offline
Force comskip to run
I've been hunting through the menus trying to find a way to force comskip to run on a show.
Is there a way to do it, or am I just not finding it?
SageTV running on: Win10 21H2
SageTV 9.2.6.976 (64 bit)
Java 1.8.0 311 (64 bit)
OpenDCT 0.5.32 (64 bit)
Clients: HD300 (x2)
HDHR3-CC Prime 20220203 (Comcast CableCard) - 3 Tuners
HDFX-4K Flex 20220203 (OTA) - 4 Tuners
Old 01-28-2022, 12:43 PM
SJQ is one way, but it takes a bit of work. I think there is an easier way.
Old 01-28-2022, 12:55 PM
trk2 trk2 is offline
You need the Commercial Detector UI plugin which will add a "Run Comskip" button whenever you select a show.
Old 01-28-2022, 10:12 PM
Yup, have that installed. I knew I had seen it somewhere and was looking on menus and settings.
Selected a recorded file for playback and it is shown at the bottom under 'Close'
Shows either:
Run Comskip or Delete Comskip Files
Thanks for the reminder
Clients: HD300 (x2)
Old 01-30-2022, 05:58 PM
DarkWolf77 DarkWolf77 is offline
I'll have to check but I thought that that particular button stopped working for me a while ago.
Old 01-30-2022, 07:41 PM
jhkoenig's Avatar
jhkoenig jhkoenig is offline
That is my experience too. No error message, but no CC icon on screen or comskip file creation.
Win10@16GB RAM, 30TB Disk across 6 disks. 2 Prime tuner units
Sage v9 (64bit) using OpenDCT to control the Primes
2 HD-300s, an Android mini-client, and a Windows client
Old 01-31-2022, 05:47 PM
Zogg's Avatar
Zogg Zogg is offline
It seems to be working for me with the new Docker, but I did discover that execute permissions weren't enabled for comskip. I had to 'chmod 777 comskip' and now it's working including the 'Run Comskip' button.
Old 01-31-2022, 05:48 PM
jhkoenig's Avatar
In my case, Comskip is running every night on the day's recorded shows, but the button doesn't have any effect. I am on Windows.
Old 01-31-2022, 08:44 PM
Zogg's Avatar
I remember the button not working, too, with my older docker.
Are you running the comskip that comes with the SageTV Windows installer? I ask because it's quite old. I have the donator's version that I use occasionally in Windows which is a lot newer, and I have it in a folder I can easily find.
In the plugin configuration, you can set the path to your own comskip folder, so if you haven't already you could get a newer version, put it in a folder, and configure the plugin to that folder. Maybe that will "fix" it. You could test with the included version in a separate folder.
I only mention all this because other than changing the permissions, I also checked the plugin configuration and it reminded me of doing all that when I set up my original Windows server.
Old 01-31-2022, 09:06 PM
jhkoenig's Avatar
I am using the Donator's version, in a uniquely-named folder as to not get overwritten by an update. I have updated the paths in the plugin setup. If I scan for unprocessed shows in the plugin setup, those programs are scanned and marked correctly, so the plugin finds the executable in that situation.
Old 01-31-2022, 09:13 PM
Zogg's Avatar
Well, other than checking the log file for any clues, I got nothing else.
Force LAN mode mayamaniac SageTV HD Theater - Media Player 5 06-09-2014 12:47 PM
Wiz.bak: Force Creation? PeteCress SageTV Software 9 12-19-2010 09:09 AM
comskip/comskip monitor - firewall?/SageMc spvoyek SageMC Custom Interface 2 12-17-2008 01:35 PM
Force add a tv show? Naylia SageTV Software 3 04-12-2007 03:37 PM
