Old 09-26-2008, 10:09 PM
getstarted getstarted is offline
I am getting java violation exception after re-installl
I had issue with sage, so i uninstalled completely and re-installed on a different drive. From there I was getting the following error while trying to preview the channel.
# An unexpected error has been detected by Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x00000000, pid=4440, tid=4984
# Java VM: Java HotSpot(TM) Client VM (10.0-b23 mixed mode, sharing windows-x86)
# Problematic frame:
# C 0x00000000
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
I tried un-installing latest JRE and re-installed. No use. Any help would be appreciated. Thanks,
Old 09-27-2008, 09:09 AM
Razillian's Avatar
Razillian Razillian is offline
What are the specs on your system? OS? Tuners? Etc...
Are you running any plugins inside of Sage?
Is this a dedicated Sage box, or do you have other things loaded?
What version of Sage?
blog: www.iamwhen.com
Java Exception Error ---> How to correct??? RasterMan SageTV Software 1 08-03-2008 11:12 PM
Java SEEKER EXCEPTION THROWN mayamaniac SageTV Software 3 04-26-2007 04:49 AM
Stumped at java exception beelzerob SageTV Studio 12 07-25-2006 11:46 PM
Sage UI disappears during playback Keith SageTV Software 17 03-03-2006 03:31 AM
Java Exception mike1961 SageTV Software 0 12-20-2005 06:13 PM
