Old 02-14-2008, 02:01 PM
phelme's Avatar
phelme phelme is offline
Wiz.bin being reset to empty?
I had a major crash yesterday morning on my server. Something went haywire in the early morning after an automatic Windows update and started writing over my C:\ drive's MFT. Trashed it bad enough that the disk refused to boot. chkdsk just made things worse when it tried to repair the MFT. I blame Bill.
Anyway, I luckily had a backup from two weeks ago from Retrospect and between that and a base TrueImage backup from a year ago I got things back up. Took most of the day to get new hardware and restore everything. Pain in the a$$.
So here's my question, the trashed drive did manage to have an intact Wiz.bin file. I tried to use it but my restored Sage server (6.3.7) kept resizing it down to 5K and starting from scratch. Now this Wiz.bin was built with 6.3.8, could that have something to do with it? For the time being, I'm using the Wiz.bin from the backup two weeks ago which stays intact, but now I have a two week hole in the data.
Any idea why this is happening? Do I need to match the Wiz.bin to the same Sage.properties file maybe?
Edit: I'll try turning on the log and see if that tells anything
Backup: Synology
SageTV version: FINAL
Old 02-14-2008, 02:06 PM
Quite possibly -- try using that wiz.bin with v6.3.8, since that is the version used when it was created. In general, you can use a newer version of SageTV with an older database, but not always vice-versa.
Old 02-14-2008, 02:37 PM
phelme's Avatar
Argh. well it appears the Wiz.bin was trashed in the crash based on the logs. Bummer. More frequent backups for me from now on!
Thu 2/14 12:21:38.785 Wizard starting to load database info...
Thu 2/14 12:21:38.789 DBFile at version 65 FileSize=14667857
Thu 2/14 12:21:38.789 Wizard allocating table for Year of size 93
Thu 2/14 12:21:38.791 Wizard loading main index for Year
Thu 2/14 12:21:38.793 Wizard allocating table for Network of size 235
Thu 2/14 12:21:38.793 Wizard loading main index for Network
Thu 2/14 12:21:38.796 Wizard allocating table for Title of size 14653
Thu 2/14 12:21:38.797 Wizard loading main index for Title
Thu 2/14 12:21:38.798 ERROR Processing DB record, skipping it and continuing. Error:java.io.UTFDataFormatException: malformed input around byte 1
Backup: Synology
Symptoms of a sick and dying wiz.bin roadtoad SageTV Software 1 12-23-2007 01:37 PM
are we there yet? wiz.bin restore/recover ssixto SageTV Software 1 01-07-2007 01:46 PM
After Lockup - Sage Not working wolfpackmars2 SageTV Software 3 08-05-2006 10:23 PM
Can Import my old wiz.bin file? jptaz SageTV Software 6 04-27-2006 05:01 AM
Is there a Wiz.bin cleaner out there? perfessor101 SageTV Software 10 04-18-2006 10:26 AM
