Old 04-23-2009, 12:12 PM
willplaice willplaice is offline
Factory reset ?
I've upset one of my hd200's is there a "factory reset" ?
Old 04-23-2009, 12:28 PM
Look in the FAQs.
HD200 doesn't work
Old 04-23-2009, 01:00 PM
ok thanks for the RTFM comment....
re-read that thread, still can't see anything... is there some way to reset the settings to default.
If the USB recovery method will reset EVERYTHING then i'll do this, but i need to be sure that all the settings exp video will get wiped before i go down this route.
thanks ,Will
Old 04-23-2009, 01:57 PM
I guess I could read it to you.
From the thread:
Q: My STP-HD200 extender is not working at all. What should I do?
A: Try the recovery procedure if nothing else works.
First, check the Troubleshooting Guide in the printed manual that came with your STP-HD200, or in the PDF manual available here: SageTV_HD200_Manual.pdf (Right click & choose "Save Target As...")
From the manual
Configuration Reset Procedure
If none of the other troubleshooting suggestions have solved the problem, then you can try this
Configuration Reset Procedure:
1. Turn the player off by unplugging the power cable.
2. Press the Delete button on the remote and continue holding it as you plug the power cable
back in. Continue holding the Delete button until the Active light blinks twice.
3. Note that you may need to use the Video Out button on the remote to change the video
output resolution.
4. After the reset procedure, check the above troubleshooting tips again.
The USB recovery is the NEXT step if the above doesn't work.
How to Reset HD200 back to Factory Defaults for Remote ace007 SageTV Media Extender 4 03-01-2009 02:04 PM
Sage Reset Itself Mike Young SageTV Software 4 12-05-2005 06:18 AM
Factory defaults? jphhughes SageTV Software 0 01-27-2004 06:15 PM
Need help how to fix Sage Recorder mpeg2 file to work with Movie Factory 2 version? tafguy SageTV Recorder Software 5 11-19-2003 12:34 PM
Audio synch problem using Ulead DVD Movie Factory newtbert SageTV Recorder Software 1 11-15-2003 03:03 AM
