Go Back   SageTV Community > SageTV Development and Customizations > SageTV v9 Customizations > Phoenix 3.0
Phoenix 3.0 This forum is for discussing the user-created Phoenix 3.0 custom interface for SageTV.
Old 07-24-2017, 11:00 PM
nateziemann nateziemann is offline
Multiple movie walls
I'm considering alternatives to Gemstone that are little less heap intensive. I had multiple movie wall views setup for kids vs parents. Is there a way to accomplish something similar w/ Phoenix 3.0? Any pointers would be greatly appreciated.
Old 07-25-2017, 03:04 AM
It's the fanart that is heap intensive - I'm not sure phoenix using a similar arrangement (wall of fanart) is going to use much less.
Old 07-25-2017, 09:59 AM
panteragstk's Avatar
You should be able to do this with VFS.
Old 07-25-2017, 12:41 PM
Or switch the server to Linux so that heap issues become a thing of the past.
Old 07-26-2017, 09:18 PM
Thanks for the pointers. If I choose to stay with Phoenix is there a way to create multiple movie walls or simply ways to filter things between kids and parents. If I have to look at 100 kids movies to find my content I may just snap ;-)
Old 07-26-2017, 09:38 PM
You can make some pretty advanced filters and groupings in Phoenix with the vfs system, but it does have a learning curve, and it's pretty much all done in .xml files.
Managing multiple seamless branching movie versions trk2 SageTV v7 Customizations 0 08-09-2014 11:41 PM
BMT Multiple Genres for the same movie?? mkanet Batch Metadata Tools 32 03-05-2011 02:32 PM
Sage Movie Wall: Will not automatically gather movie data? (Art, IMBD, etc) therealtybutler SageMC Custom Interface 6 09-22-2009 01:58 AM
Multiple Tuners & Movie Codecs jaminben SageTV Software 5 09-14-2007 05:54 AM
at root menu of DVD movie, can move cursor, but can't select (play movie)?? mattress SageTV Software 1 09-04-2006 11:15 AM
