Old 01-29-2008, 03:09 PM
Bacon2002 Bacon2002 is offline
DVB-S Scanning problem
Hi,
I have a couple of TechnoTrend cards that I am trying to get to work with SageTV.
The cards are:-
#1 TechnoTrend TT-S1500
#2 TechnoTrend TT-S3200
My problems are as follows:-
1) #1 Card will not scan for channels.
The process to channel scan I have tried is - Setup, Video Source, select card #1, confirm the provider (Astra 28.2), select no EPG/XMLTV, select Channel Scan - Yes, a small windows opens show channel scanning 0/0 but after 5 or so seconds the window closes and no channels are found.
2) Sometimes SageTV will channel scan with the #2 card, if it does work (seems to be randow as to if it works or not) then it will find 700+ channels (UK Sky Digital).
Are there any tips, tricks, text files, setups or files I can change in order to fix this problem.
For information:-
The cards seem to co-exist in the PC OK and work simultainiously with other software - MyTheatre, TT-Media Center, SageTV (when card #2 works and I use one of the other DVB programs) etc.
The system is a AMD 4800 X2, GigaByte GA M56S-S3, TT-S1500, TT-S3200, ATI X850, 2GB OCZ Plat DDR2 6400, Vista 64 Ultimate.
Any help would be greatly appreciated.
David
TVTV problem fresdy SageTV EPG Service 1 01-20-2007 03:56 AM
PVR 150 PAL\NTSC problem Dror Engel SageTV Software 1 12-31-2006 12:54 AM
Directx/decoder problem Grasshopper SageTV Software 0 04-28-2006 04:59 PM
Problem with Scheduling Look Ahead nerys SageTV Customizations 2 04-26-2006 01:45 PM
First Run "Simpsons" problem swishbish33 SageTV Software 5 04-15-2006 11:23 PM
