Old 02-22-2022, 11:48 AM
phelme's Avatar
phelme phelme is offline
Question Well, this is odd, recorded shows suddenly being renamed to "Surround" or "Stereo"
I'm not sure what I did, but starting Sunday Feb 20th, a variety of new (and some old!) recordings have had their media types changed to "Movie" from "TV" and their titles and episode names changed to either "Surround" or Stereo" And they also lose their recordings status and are relegated to being imports. Quite a Mess.
here is a snippet from phoenix.log that shows it has already happened to a couple new recordings from last night:
2022-02-22 05:41:41,952 - AUTO; MEDIA; \\sagetv-server\BigMedia2-Recordings\Jeopardy! - S38E116 - 97215031-0.mkv; Surround; 97662797
2022-02-22 05:41:41,972 - SKIP; \\sagetv-server\BigMedia2-Recordings\Jeopardy! - S38E116 - 97215031-0.mkv; Surround; 97662797
2022-02-22 05:41:42,381 - AUTO; MEDIA; \\sagetv-server\sagetv\Below Deck Sailing Yacht - S03E01 - Tom Foolery - 97218059-0.mkv; Surround; 97662800
I had been playing with the phoenix-renamer as well a couple of days ago, but I never installed it in the Sage folder or anything to put it in play.
The *only* thing I remember changing on Sunday, was modifying the
"extended_filenames" property from "false" to "true," and that adds spaces and whatnot to the file name.
What I'm wondering is if my overnight SJQv4 process, which runs MediaShrink to convert new recordings to mkv's is involved. Maybe, once the extension type has changed from .ts to .mkv and rescanned by SageTV, things go haywire now that there are spaces? It sure feels like it's BMT/Phoenix doing something, but I don't know why.
For now, I've changed back "extended_filenames" to "false" to see if that fixes it.
I've scanned what logs I can think of and all I found was the phoenix log showing they already had been changed late in the morning. I have yet to go through all the sagetvXX.txt files. I notice the new jetty is throwing a lot of exceptions in there so have to figure that out (some are related to not finding channel icons).
and what's up with the titles being picked, Surround or Stereo??? sure feels like that's being grabbed from the metadata of the show itself.
Anyone out there have any ideas of where to look? thanks!
Old 02-22-2022, 02:44 PM
jusjoken jusjoken is offline
Some thoughts..
  • Jetty has nothing to do with file naming so I would not bother looking there
  • Phoenix renamer does not need to be installed as far as I am aware. it uses sagex remote processes to use sage and Phoenix functions but also runs only on demand unless there is an auto process I am not aware of
  • new media defaults to MOVIE unless it matches a rule you created to make it TV
K
Old 02-22-2022, 04:28 PM
phelme's Avatar
Thanks K.
It feels like this might be happening by CMT/BMT due to properties file building after recordings are finished. They take priority in SageTV metadata, right? And if I'm not mistaken, there were some changes to some of the JARs used by them in the jetty upgrade. Can't be a coincidence. You may be correct that these were seen as new media Movie files because their recording info was wiped.
I ran a couple tests after changing extended_filenames back to false and so far things are fine.
Still can't figure out why Stereo and Surround were being used as title names. Haven't found anything useful in the sagetvXX.txt files I had available.
Old 02-22-2022, 09:44 PM
JREkiwi's Avatar
JREkiwi JREkiwi is offline
I can categorically say CMT does absolutely NOTHING with file names
John
Old 02-23-2022, 07:39 AM
I imported a few files over the past few days and one of the files I imported yesterday ended up with a name of "Surround 5.1". See the attached images..... I have never seen this before..... Is this a defect or maybe a change on the source pages the data is being pulled from?
Old 02-23-2022, 10:46 AM
Perhaps TVDB changed their api again. We are using an old api and I believe they fake out the old apt to call their new api which caused TV banners to fail a few months ago. this could be similar.
Can one or both of you post a complete Phoenix and Metadata log after the issue occurs and I will look into it.
K
Old 02-23-2022, 11:05 AM
I would be happy to provide a log but not really sure where to find this??? Sorry......
Old 02-23-2022, 12:39 PM
I also took a look at the video properties file for the imported video and this was all that was in it.....
"PropertiesWrittenBy=CMT"
Old 02-23-2022, 01:10 PM
phelme's Avatar
hey I'm not alone!
K
it hasn't happened again since I turned off the extended filenames. might be just a coincidence.
I enclosed two sets of what I have. unfortunately these look like they are recycled every so often so I don't have one from Sunday where there were more samples. there are definitely some TVDB exceptions going on.
thanks for looking into this!
Edit: looks like I have some network permission problems on the Fanart folder. I recently redirected it from "Programs Files (x86)" to "Program Files." Have to fix that.
Old 02-23-2022, 01:13 PM
phelme's Avatar
on Windows: C:\Program Files\SageTV\SageTV\logs
Old 02-23-2022, 02:06 PM
I am on an unraid server I will take a look after work and see if I can determine the files to send! Thanks!
Old 02-23-2022, 02:31 PM
Hope this helps!
File Type: zip phoenix-metadata.zip (448 Bytes, 22 views)
Old 02-26-2022, 08:53 AM
I set up a clean system with my 8000 test files (series and movies) and all of them received proper titles through TMDB and TVDB. None were named oddly like Surround.
I also ran all the built in tests in the phoenix core project and all the tests passed.
I will give this more thought but am at a loss why the two of you are seeing this issue.
K
Old 02-26-2022, 08:24 PM
phelme's Avatar
thanks for looking into this. I haven't had another incident since I changed the extended_filenames property back to the way it was (false). I'll try setting it to "true" sometime this week and see if anything happens.
Old 02-27-2022, 07:24 AM
So I believe I have identified the issue that is causing the incorrect file names. At least in my example. Gonna try and keep this short and clear.....
If you remember jusjoken, a couple weeks back you helped me with a different issue with Imported title lengths being zero length. In the end I updated my Docker from a very old version to the newest Java 11 version and reset the permissions on the ffmpeg file in the server directory. This fixed not only that issue for me but a few other issues with No video when using the placeshifter. All was good.
Then I installed the Linux version of the SageTVTranscoder plugin as I have been trying to improve the ability to watch SageTV in a remote location smoothly and in good quality. THis was about two weeks ago and all seemed good. I had imported a few files since then without issue. In fact the day I imported the file that got the name "Surround 5.1" I imported 3 other files which imported fine.
So based on the above and your test results I decided to uninstall the SageTVTranscoder plugin, delete the incorrectly named file and reimport it to see if it made a difference. When I imported the file this morning it got the correct name but was again zero length. So I reset the permissions on the ffmpeg file and deleted and reimported the file and it worked correctly with the correct file name and length. Clearly uninstalling the SageTVTranscoder plugin does not appear to correct the permissions on the original ffmpeg file.
Then I reinstalled the SageTVTranscoder plugin and did the delete/reload dance again and the file was again named "Surround 5.1". Once more I deleted the SageTVTranscoder plugin and reset the permissions on the ffmpeg file and did the delete/reload dance again and the file was totally correct.
It appears that the SageTVTranscoder plugin or a conflict with that and something else is causing the issue for me. It does though only impact (at least so far) the one specific file as I imported about 5-10 video files over the two weeks I had the SageTVTranscoder plugin and all others seemed to import correctly.
Sorry for the long winded answer, and sorrier if it is not clear, but for now I have uninstalled the SageTVTranscoder plugin and will leave it this way until there is another update. Not sure that is the only or the whole issue, but clearly when it is installed something is not right!
Old 02-27-2022, 11:46 AM
Definitely clear...thanks for the great testing and details. I am not at all familiar with that plugin so you may want to post a link to these details in the thread for that plugin as the author may be able to assist.
K
Old 02-28-2022, 01:40 PM
phelme's Avatar
i have this as well, but on Windows. have had every iteration since it came out in 2020.
phantomii, did you happen to save the logs when you did the import again and it failed?
Old 03-01-2022, 04:59 PM
I did not save the files again as I went through the import. I could (in theory) do this again if it would add real value above the imports files I already posted. Would need to find and hour or two to do it. Maybe this weekend time will allow.....
Old 03-02-2022, 12:23 PM
phelme's Avatar
you're definitely on to something. it's some interaction between plugins after video/recording files are scanned for media info entry.
In my case, it has something to do with nightly compression which changes file extensions from ".ts" to ".mkv" which causes SageTV (and plugins) to take another look at the files. as I said, it hasn't happened again for me since I toggled "extended_filenames" back to "false." I did that for Plex use actually, but since the SageTV media scanner for Plex works fine the way it is, I probably won't change the extended property back.
"Backdrops" "SageTV" "Covers" folders - what's creating them mp328 Sage My Movies 4 09-20-2010 05:31 PM
"Sort By Title" most shows end up under "T" as in "The" grauchy SageMC Custom Interface 1 09-25-2009 06:44 AM
Would love to see a "Recorded Shows" view for "Videos" (SageMC)... Addict SageMC Custom Interface 3 08-02-2008 09:47 AM
"Set defaults" for Series forgets "Keep"/"Auto-delete" setting maxpower SageMC Custom Interface 9 05-14-2008 09:44 PM
