Old 12-24-2020, 07:23 PM
jimcgreen jimcgreen is offline
SageTV crashing with java exception access violation
Lately my SageTV client has been crashing with a Java EXCEPTION_ACCESS_VIOLATION (0xc0000005). I am running SageTV 64 bit version 9.2.1.826 on Windows 7 Pro. Java version 1.8.0_271. Any ideas of what I should do to fix this?
Error log hs_err_pid4476 is attached.
Old 12-26-2020, 06:31 AM
I'm not a windows person, but, the crash report seems to indicate that it crashed while setting the video filters. Has anything changed lately on your system?
Old 12-27-2020, 11:25 AM
Thanks. Video might be a clue. The last thing that happened was a hard drive crash but I was getting the error before that. I have 2 Hauppauge Quad-HD cards installed. I see that there is a more current driver available. I'll try updating the drivers on those cards and see what happens.
Old 12-27-2020, 12:54 PM
wnjj wnjj is offline
It’s crashing during the video renderer setup (i.e. playblack). This won’t have anything to do with video capture cards. It may have to do with your graphics card drivers.
You can try changing the renderer settings within SageTV setup though I honestly can’t tell you what to specifically set anything to.
Windows Installer
Old 12-27-2020, 01:45 PM
Thanks. I'll update the graphics card driver too. There is a driver that is dated 9 days after the one I have installed.
The error is intermittent. Sometimes it happens just once in a month and other times it happens 6 or 7 times in a month.
V9 crashes during channel preview EXCEPTION ACCESS VIOLATION wayner SageTV Software 0 04-01-2017 03:14 PM
SageTV Client - Java Exception davidjames SageTV Beta Test Software 1 06-06-2011 05:00 PM
I am getting java violation exception after re-installl getstarted SageTV Software 1 09-27-2008 09:09 AM
Testing Sagetv with Java Access bridge nallan SageTV Software 0 04-01-2006 07:31 PM
Beta V1.2.2 Java java.lang Null Pointer Exception hamptonhills SageTV Beta Test Software 1 03-27-2003 12:11 PM
