Old 01-04-2006, 08:14 PM
mm_junk1 mm_junk1 is offline
Web Remote error - "Webserver running in Service mode -- cannot execute any commands"
Can anybody help?? Please...
I have recently installed WebServer V2.3 and i've gotta say this is awesome. It only took like 5 minutes to install and it works great!! Thanks nielm!!
However, I am having problems with the Web Remote function. I get the error message
I'm not sure if I'm being stupid or what but i've searched all around the forums and can't find a solution.
Basically, when I click on any button on the Web Remote it throws up the error above.
Is this due to the fact that I am running SageTV as a Service? Is there any way of fixing this ...
I would like to use this feature with my iPaq and WiFi to change channels via wireless.
Any help is greatly appreciated.....
M
Old 01-04-2006, 09:05 PM
Yup, the service is completely disconnected from the UI/playback function.
Try moving the webserver entries to the sageclient.properties file
Old 01-04-2006, 11:34 PM
Thanks for the reply stanger89
I have removed all of the entries in the Sage.properties file and added them to the SageClient.properties file. BTW, this is the SageClient.properties file on the Sage Server PC and not the Sage Client PC
I can access the WebServer OK but still can't use the Web Remote.
Even when I turn off the Sage Server and stop the Sage TV Service I still can't use the Web Remote. Is their something i'm missing?
Is the web remote known to work OK with SageTV?
M
Old 01-05-2006, 12:32 AM
jreichen's Avatar
jreichen jreichen is offline
This problem has been reported here http://forums.sagetv.com/forums/showthread.php?p=131224&postcount=794.
Toward the bottom of the page Nielm explains the problem and when to expect a fix.
Server: Intel Core i5 760 Quad, Gigabyte GA-H57M-USB3, 4GB RAM, Gigabyte GeForce 210, 120GB SSD (OS), 1TB SATA, HD HomeRun.
Extender: STP-HD300, Harmony 550 Remote,
Netgear MCA1001 Ethernet over Coax.
SageTV: SageTV Server 7.1.8 on Ubuntu Linux 11.04, SageTV Placeshifter for Mac 6.6.2, SageTV Client 7.0.15 for Windows, Linux Placeshifter 7.1.8 on Server and Client
, Java 1.6.
Plugins: Jetty, Nielm's Web Server, Mobile Web Interface.
Old 01-05-2006, 12:35 AM
Thought I'd better mention that my SageTV Version is v4.1.3.67
Java Version - 1.5.0_05
M
Old 01-05-2006, 01:34 PM
You'll have to run the webserver on whatever PC you want to control.
Old 01-05-2006, 01:41 PM
Thumbs up
Thanks everybody for the assistance. Looks like there is a fix in the Pipeline for SageTV Version 4.1 users of the WebServer . . .
M
Old 01-06-2006, 07:48 AM
nielm's Avatar
nielm nielm is offline
Fixing webremote/play in SageTV functionality for 4.1 is a high priority item on the todo list
I am hoping to add webremote support for MVPs at the same time.
However the highest priority item on the todo list is actually upgrading my systems to 4.1
Old 01-08-2006, 03:57 PM
Thanks nielm!!
Good luyck with the upgrade. Looking forward to the new version.
Cheers
M
Old 01-18-2006, 11:22 PM
Thanks for the WebServer update nielm. I have installed it but I am now getting the following error.
UI Context: "SAGETV_PROCESS_LOCAL_UI" is not active:
use: /sage/SageCommand?command=<command>&context=<context>
Do I need to set up Commands in SageTV to make the Web Remote work?
M
