Old 11-27-2003, 12:51 PM
metropole metropole is offline
Hauppauge 350 and composite input
I'm trying to get composite in working on my Hauppauge 350.
I'm using a composite to svideo converter (I beleive it came with the card?).
However all I'm getting is black and white.
Does anyone have composite in working?
Also, does anyone know about a solution (a box) that would automatically switch between comp and s video depending on the input and output svideo?
Old 11-29-2003, 10:54 AM
dkardatzke's Avatar
dkardatzke dkardatzke is offline
SageTV Co-Founder
Upgrade to the latest Hauppauge drivers and that should fix your problem. With the latest drivers you will have a number of composite choices so you may have to try each one to get the right one.
Dan Kardatzke, Co-Founder
SageTV, LLC
Old 11-29-2003, 03:01 PM
carlgar carlgar is offline
Can you provide version numbers for what you refer to as latest drivers? Some people may read a post such as this months after they are posted.
Can you respond to my post at Should latest Hauppauge drivers work on 350 with SageTV?
Old 11-30-2003, 09:42 AM
Do I need to really uninstall the existing driver prior to upgrading to 1.7?
Old 11-30-2003, 11:43 AM
I didn't, but you do need to run HCWCLEAR which appears to do the same thing as a uninstall. You do need to uninstall the Hauppauge Video decoder. I just installed the latest Hauppauge drivers dated 10/10/2003 with version number of 1.17.390.21283
I just followed the Hauppauge instructions.
It did not correct any of my problems related to multiple tuners but hope you have better luck.
