Old 01-03-2018, 02:40 PM
rickgillyon's Avatar
New Android TV Box and Miniclient
I have a new Amlogic S905W cheap Android box. Got a lot of similar around the place, this is a new brand on me. Like all of them, it's set up as 1080p. Unlike the others, in MiniClient it's showing as 1280x720. Any ideas why that should be? Just going to return it if not...
unRAID Server: Intel Core i5 7600K, 48GB DDR4, 2x512GB PCIe M.2 Cache Pool, 2x10TB SATA3 Parity Drive, 3x8TB SATA Array, 1x hdHomeRun DVB-T2 Quattro, IPTV via xTeVe, unRAID 6.8.1, tvHeadEnd for recording back end, OpenDCT, SDEPG, SageTV 9
Clients: 3 Nvidia Shields, 1 FireTV, 2 Android Miniclients (Amlogic S905X), 3 Win10 Pro PC Clients
Old 01-03-2018, 02:52 PM
Is the miniclient only taking up 3/4 of the screen? Or is the miniclient rendering full screen but it's only showing 1280/720?
Old 01-03-2018, 03:27 PM
Probably my description could be better...
Full screen, shows 1280x720 in system information. In the Miniclient settings it shows something like 1280x688 in "Native UI Resolution" before launch, but if I try to change this to 1920x1032 it just ignores my input and changes back.
Old 01-03-2018, 04:20 PM
yeah, the reported size is the size that the Android OS is reporting as it's screen size. So either the device doesn't support 1080p or the hdmi connection to the device choosing 720p instead of 1080p... or, the device runs its UI at 720p by switches to 1080p for video??
Old 01-03-2018, 05:19 PM
It seems to support 1080p (the options are there) and I've fixed it at 1080p and told the HDMI not to adapt. Probably the UI, but I'm assuming this would lead Sage to display at 720p. So probably not worth the trouble. Next! Thanks for the help.
Android MiniClient 1.2.9 stuckless SageTV Clients Development 53 04-16-2018 07:30 AM
Android MiniClient Control? wayner SageTV Clients Development 3 01-06-2018 11:14 AM
Android MiniClient issue crarbo1 SageTV Clients Development 4 02-13-2017 11:18 AM
Android MiniClient - ExoPlayer stuckless SageTV Clients Development 46 12-28-2016 01:46 PM
Android Miniclient and UK TV rickgillyon SageTV Clients Development 6 12-01-2016 05:58 PM
